Remove these ads by
Signing UpStep 1: Remodeling
Then there is the inside; kitchen and bath! I will be sharing as we finish each job here on instructables. Most people would start on the inside but we have a large yard and a small house so we needed a shop to store everything and a place to work and keep tools and materials protected.
The concrete is almost all finished except for the driveway. That will be the last thing we do. For this instructable I will be sharing how we poured a section of sidewalk to finish the concrete for the back yard. We hope to finish the shop and plant the lawn very soon. I mention this to you because if you will be doing any of these things, you might keep an eye open for my new instructables as I share them here.
Visit Our Store »
Go Pro Today »
I live in Cleveland which is a colder climate and we get a lot of rainfall so freeze/thaw and drainage are major factors. Now I should also say that I'm an architect and by definition lazy. I put stuff on paper and have others do all the work :)
add a 4" layer of gravel below the sidewalk. this as a drainage plain so that subsurface water will drain away from the sidewalk and there it is less likely to heaving. if you are also incorporating paving like bricks then I will add a 4" layer of sand on the gravel.
instead of using 2x for formwork use siding boards and wooden stakes. siding boards are flexible and can be straight or easily bent to make nice smooth curves.
4" minimum depth and add reinforcing mesh, usually 6x6 w1.4/w1.4. as you pour hold the mesh in the middle of the slab.
add expansion strips whenever butting up against existing paving or foundation.
slope the sidewalk to one side for drainage. this is simply done by setting one side of the formwork a lower than the other side.
as a general rule i use 3'-6" minimum (preferably 4') for walks because unfortunately down the road someone may be in a wheel chair, so it's good to make things wheel chair width. a wheel chair can fit on a 3' wide walkway but it's good to give a little breathing room on either side to keep from rolling off the edge.
add 2" pvc pipes (1' wider than walk) under the sidewalk at logical locations for future sprinkler lines and wiring for outdoor lighting. cap the ends of the pipes but don't glue it so that the pvc won't get clogged with dirt. when you pour the walk, add marks in the concrete so you can easily locate the pipes down the road.
Sunshiine
sunshiine
To answer your question, the best time of year is summer. He also said:
I assume he will be buying a sack of asphalt patch or /mix at a local building supply center. If you are ordering it through a paving company it will come from the batch plant approximately 200 degrees F. Summer or winter should not matter but it should be done on a day when it is not raining. If you are buying it from a sack at a local building supply center, it should be poured on the hottest day of summer.
I hope this helps! Thanks for commenting and have a great day!
Sunshiine
Sunshiine
Sunshiine
Best of Luck, girl!!!!!!!!!!!!!!!
Sunshiine
Sunshiine
Sunshiine
sunshiine
(also, your pictures are fantastic)
Sunshiine
and in step 11 you'd better use a trowel than hands
Sunshiine
Sunshiine
