Concrete Solar Light
14,080
244
6
Posted in WorkshopMolds-and-casting
Introduction: Concrete Solar Light
About: Hello - I am the scientist formerly known as Naegeli and of course I was inspired by the artist formerly known as Prince. But in contrast to his royal badness I do not want be become the king of pop but the ...
This instructable shows you how to make a stand for a solar floor light so you can use it as a stand-alone unit on a table. The stand is made from concrete and therefore perfectly suitable for outdoor use. Moreover the light is eco-friendly and use solar panels to collect sunlight and charge batteries that power the lights when dusk falls. The video on how to make the concrete solar light can be found under the following link (Link).
I was attracted by the shiny stainless-steel cover of this particular solar floor light so I had to buy one. Living in a rented flat, there was no opportunity to mount the light somewhere. But I thought that it would be nice to have such kind of "tea light" outside on my balcony. Maybe not to drink tea aside but I was thinking more of a nice glass of wine during sunset.
The following materials are needed to complete the project:
  • Solar light
  • Cardboard
  • Tape
  • Empty tape roll
  • Stanley knife
  • Salad bowl
  • Concrete mix
  • Water
  • Sunflower oil
  • Balance
  • Sand
  • Hot glue gun
  • Toothpick
  • Milk pack
  • Popsicle sticks
  • Razor
  • Sand paper
  • Concrete base coat
  • Paintbrush
Step 1: Making the Mold
The idea is to make a replica or model for the solar light out of cardboard. A first disk of cardboard is made in the same size of the stainless steel cover. Then three cardboard disks are cut for the part directly under the stainless steel cover. These four cardboard disks are completely covered with tape to make them waterproof. With the help of a toothpick that is placed in the center of the largest disk the three others are glued on top with the help of a glue gun. To finish the main part of our model an empty tape roll was used having a slightly bigger diameter than the main body of the solar light. It is always good to keep such items during the year. You never know when you need them. The empty tape roll then is glued on top of the cardboard disks.
Our replica or model for the solar light is now ready to be placed in the salad bowl. In order that the cardboard model withstands the weight from the concrete regular sand is placed on the bottom of the salad bowl. Now place the cardboard on top and you are ready for pouring the concrete.
Step 2: Pour the Concrete
Start rubbing the inner surface of the salad bowl with oil (sun flower oil) in order to achieve a very nice surface and that the concrete after drying can be easily removed. With the use of a balance I usually mix the correct amount of concrete with water according to the instructions of the supplier. The compounds are then mixed in a milk pack using a popsicle stick.
After careful mixing, the first part of concrete is poured into the mold. With the help of the popsicle stick the concrete is distributed evenly. Then the rest of the concrete is added. To remove air bubbles I usually hold a razor against the salad bowl. The vibration helps to remove the bubbles and assures a smooth surface.
Let the concrete dry for a day.
Step 3: Taking the Stand Out of the Mold
After the required drying time carefully remove the concrete out of the salad bowl. Then remove the tape roll and the cardboard. Let the concrete dry completely.
Step 4: Finishing
Use sand paper to make a smooth surface. Remove the dust an apply a layer of concrete base coat. Place the solar light into your stand.
    • Spotless Contest
      Spotless Contest
    • Microcontroller Contest
    • Science of Cooking
      Science of Cooking
    6 Comments
    Jetzt habe ich dein Instructable gefunden. Kompliment, die Arbeit wie auch das Endprodukt gefällt mir sehr gut.
    Nice ! I might have to give this a try :)
