Introduction: Concrete Lamp (2)
Picture of Concrete Lamp (2)
Another concrete lamp, one of my favorites. It will take you less than 30' to make one!
Let's see how...
Step 1:
Picture of
Parts you need:
A plastic food box, a complete cord (with switch and plug), an E27 socket, two socket rings and a rubber protective furniture pad.
Step 2:
Picture of
Tools you need:
Rubber to metal adhesive (I mostly use the 3M Industrial Adhesive), vinyl electrical tape, super glue, a screwdriver, a modelling knife, a reamer, a marker and a soldering iron.
Step 3:
Picture of
Mark and cut with the soldering iron a hole about 40mm for the socket, then trim the hole with the modeller's knife.
Step 4:
Picture of
Make a 14mm hole for the cord.
Step 5:
Picture of
Make a hole at the side of the socket for the wires.
Step 6:
Picture of
Before assembling socket dont forget to install the rubber pad which will protect the cable from bending.
Step 7:
Picture of
Socket assembled and insulated with super glue. The ring also was glued.
Step 8:
Picture of
Cover the holes of the ring with electrical tape.
Step 9:
Picture of
Double check you have applied electrical tape to every hole and super glue between upper and lower socket part.
Step 10:
Picture of
Put all parts together. Rings will keep the socket in place and pad will secure the cord.
Step 11:
Picture of
This is how it should look.
Step 12:
Picture of
Fill with concrete and let it cure for 24h.
Step 13:
Picture of
Then cut mold with the soldering iron.
Step 14:
Picture of
Let it dry properly.
Step 15:
Picture of
Wet-sand the bottom with 150 grit sandpaper.
Step 16:
Picture of
Apply self adhesive pads and trim the edge.
Step 17:
Picture of
Fine wet-sand it with 800 grit sandpaper and replace the plastic ring with a metal plated one if you like.
Step 18:
Picture of
Now your lamp is ready.
Step 19:
Picture of
I use a blue led string bulb and I love it!
Step 20:
Picture of
For more projects please visit my facebook page, like and share!
Thanks for looking,
Stamatis
HjoacoM (author)2017-12-23
Excellent, clean and simple.
What is the name of the lamp??
Stamatis K (author)HjoacoM2017-12-23
Hi. Please google "starry led string bulb". It think this is.
halciber (author)2017-12-21
Nice project, and a well done Instructable. Thank you.
Amit_Jain (author)2017-12-16
nice idea
Stamatis K (author)Amit_Jain2017-12-17
About This Instructable
3,653views
62favorites
License:
Bio: Just making concrete lamps as a hobby...
More by Stamatis K:Concrete Lamp (7)Concrete Lamp (6)Concrete Lamp (5)
Add instructable to:
