3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Magnum Condom LED Music Light
Sound Activated Condom Lights. Must see the video ending :)
Step 1Supplies used,
Supplies used,
2 Blue 5mm LED's 3.7 volt 2600mcd
2 5mm LED Holders
2 Condoms
Heat shrink wrap
Some thin gague wire. I used an old phone cord.
Clear Silicone
2 tops off a Gaterade bottle
Multimeter
Electrical Tape
Wire strippers
64 comments
1-40 of 64next »
Mar 5, 2009. 8:03 AMNoahArca says:
Ha this is very creative! I'm really diggin the music you used too! Who is it by?
May 14, 2009. 6:42 PMmateusz719 says:
I dont want to break the news to you, but a friend made it for the guy, so you can't really get it.
Oct 26, 2010. 2:06 PMNoahArca says:
DAMNNNN that sucks.
Oct 2, 2007. 4:04 PMteeznutz says:
compressed air is for wimps. why not use your mouth? come on, please? just this once?
Jul 10, 2009. 1:51 AMMJTH says:
Lol
Jul 10, 2009. 1:49 AMMJTH says:
Maybe want to say Non Lubricated Condom?
Jun 27, 2009. 10:16 AMThe Fishfrog says:
That is sooo very err........ koooooooooooool!!!!!!!!!!!!!!
Feb 12, 2008. 12:32 AMWildSavage says:
well my LED burned..
it worked and i volume my speaker up, the LED actually started to turn into red and burned. :(
but for the whole things, it works though.
Wave thro the LED- let it FLOW~
Apr 3, 2009. 2:03 PMerral says:
did you add a resistor to the LED ?
Apr 8, 2009. 2:45 AM-Aj- says:
am guessing not :P or speaker level was too high
Sep 30, 2008. 2:49 PMcorey_caffeine says:
it's an led safey!!!
Aug 23, 2008. 4:57 PMgeoffcubed says:
To avoid any damage you could use fast switching relays. WIth relays you could also run larger lights...
Sep 20, 2008. 12:53 PMalex-sharetskiy says:
but relays cause access noise, and they are slow
Sep 5, 2008. 3:08 PM=SMART= says:
Hahahahahahahahahahah ROFL
Aug 30, 2008. 11:42 AMo WONDERBREAD o says:
how do i connect the wires to my speakers?? faved and 5*
Sep 21, 2007. 9:37 PMsumguysr says:
there are two problems with this implementation, first is that an LED is a diode and audio signals are ac, so the audio that reaches the speakers would be rectified and you would only hear the top or the bottom of the sound waves, the second is a diode represents a constantly changing series impedance which would destroy the impedance matching between the speakers and the source, resulting in bad sound at best and equipment damage at worse.
Aug 10, 2008. 6:06 PMgeoffcubed says:
What if you hooked just the LED to the Speaked output. Left channel music right channel Lights? Still the second greatest thing to use a condom for
Aug 23, 2008. 2:59 PMviacin says:
Yes, I've seen many of these LED instructables, all running on A/C, I wonder if you could use your d/c powered iPOD instead. Just cut the headphone cord and install the led. If you want to hear the sound too, you can get a speaker set for a little bit of nothing on eBlah and do the same thing. Heck...This calls for a new instructable! Seeing as I dont own a iPOD (fighting the man, or some such), I wouldn't mind someone stealing my idea. Maybe it's already been done?
Aug 24, 2008. 4:39 AMsumguysr says:
viacin your missing the point. The power that the source uses doesn't matter, it's the electricity coming out of the headphone port that does. Analog audio is always AC. I would think an LED would be even worse on an iPod actually since iPods output much less power than most stereos and I think(but don't know) that a constantly changing impedance mismatch would be much more noticeable on a pair of high impedance headphones(16 to 32 ohm) versus lower impedance(4 or 8 ohm) speakers. geof, it would probably work to use an led on just one channel with no speaker but you would have to add a fairly heavy duty resistance as well since most audio sources don't like playing into shorts. Also I would put 2 LEDs in parallel but with reverse polarity, so that the audio source didn't see any rectification.
Jul 11, 2008. 3:35 PMMJTH says:
Im Glad You didnt use your mouth to blow that up.
Aug 23, 2008. 3:00 PMviacin says:
lol, I was wondering!
Tesla would be proud.
Jul 30, 2008. 11:32 AMvpsekharan says:
The circuits and building instructions are very intersting.
Jul 14, 2008. 6:17 PMslappy-jacks says:
jesus u can do alot with condoms
Jun 29, 2008. 6:53 AMfkuk says:
dont you have a better use of condoms?
Mar 27, 2008. 7:31 PMstatic says:
I'm wondering at what point during normal condom use, one pauses to think; Wouldn't it be far out if I did this with a condom?
Feb 23, 2008. 2:13 PMthemolok says:
F*cking Awesome!
Sep 23, 2007. 9:14 AMandrew101 says:
oh and a better way to tell positive and negitive on the led isnt wich lead is longer (because not all are) look really closly at it its round but one side (at the base) is flat the flat side is negitive.
Feb 23, 2008. 8:57 AMzzag says:
The way I remember: "Cathy is short, flat, and negative." I.e. Negative leg is determined by: The cathode is the short wire and/or the flat of the bulb. (If your mind is as bad as mine, it's yours free of charge.) .
Feb 18, 2008. 8:00 PMinertia18 says:
can you please post the song here. Its fantastic. thanks nice instructable a plus for you dude.
Feb 16, 2008. 7:40 AMpegassuss22 says:
What is that song??? tnx
Feb 16, 2008. 3:29 AMMacka says:
lol, that looks awesome. Maybe now i'll have an excuse to buy condoms :D
Feb 5, 2008. 12:56 PMZujus says:
Really cool, but still need more good quality photos to be perfect.;)
Jan 13, 2008. 6:41 PMMrSootentai says:
I love this video, and I actually want to do the project, but I'm still confused on the wiring. Can anyone draw a diagram or something for me?
Nov 28, 2007. 1:34 AMgotclawz1 says:
i really want to do this and i have the right speakers but im not sure what wire to hook it up to. note 1 wire goes to my comp, 1 goes to left speaker and 1 goes to the wall, so which one is it?
Nov 19, 2007. 2:08 PMJ_SCAP says:
lol light up penises roflmao
Oct 27, 2007. 7:30 PMitsME_lulu says:
it's so cool but i'm lost...can u make it more specific on the info because i'm confused where to hook the wires to. please... thanks.
Oct 25, 2007. 4:10 PMYerboogieman says:
i dont see how that would work.....please explain? im not sure much power goes to the speakers......
Oct 9, 2007. 5:43 PMDarthdoom says:
Didn't work for me, work with any speaker?
1-40 of 64next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:fishin4daze
