3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Conducting foam controlled servo's
video Conducting foam controlled servo's
This video shows the use of conducting foam as an input for the Arduino Duemilanove. The output consists of 2 servo's which, eventually, will control a robotic hand.
The conducting foam was taken from a pcb-case (originally to prevent static build up).
The Arduino scetch is found in extended->servo->knob and doubled (or tripled etc.) for control of more than 1 servo.
http://www.youtube.com/watch?v=Yfiv_CDozds
10 comments
Jul 2, 2011. 12:44 PMrenaissanceman says:
Thanks very much for the code, I'll try it later, no time this week. Anyway I'll let you know how it works !
Jun 30, 2011. 12:10 PMetopsirhc says:
nice idea , but u might wanna smooth out the shakiness in the servos
witch can easily be done with an if statement and some math .
lemme know if u want to know the code , even though idk if it is arduino compatable ( c++ code like)
Jul 2, 2011. 4:01 AMrenaissanceman says:
I'm an electronics man myself so any code to improve the electronics is welcome !
Jul 2, 2011. 9:59 AMetopsirhc says:
heres an example for a single servo and input
i did a little research on how arduino works  so it may actualy work right away , but its compleatly untested
#include <Servo.h>
Servo myservo;
void setup()
  myservo.attach(9);
  myservo.write(90);  // set servo to mid-point
void loop() {
int calibrate = [ a number to mess around with ]
int an0 = map(analogRead(0) , 0,1025 ,0,180)
If (an0 => (an0 + calibrate )  )
   myservo.write(an0 )
else if ( an0 =< (an0 - calibrate ) )
   myservo.write(an0 )
what this does is checks to see if the the analog pin ( after being mapped to work with a servo ) is within [calibrate] range . if its not in that area , it will change the servo's position ... i hope
lemme know if it works =D
Jul 2, 2011. 10:04 AMetopsirhc says:
>< just noticed
add a semi colon to the end of every statement except the if , and else if
example :
void loop() { <--- not here
int calibrate = 5 ; <---- here
If (an0 => (an0 + calibrate ) ) <--- not here
myservo.write(an0 ) ; <--- here too
Jun 21, 2011. 3:16 AMBongmaster says:
what vid?
Jun 21, 2011. 6:47 AMBongmaster says:
kools, im in the north XD
Jun 21, 2011. 6:48 AMBongmaster says:
yup its there
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:Renaissance-man
