3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Conductive Fabric: Make Flexible Circuits Using An Inkjet Printer.
Extremely flexible and nearly transparent circuits can be made using conductive fabrics. Here are some of the experiments I've done with conductive fabrics. They can be painted or drawn on with resist and then etched like a standard circuit board. Conductive glue or conductive thread is then used to attach the components to the fabric circuit board.
To make this clear, the inkjet printer is not used to directly print resist onto the fabric. Instead, it is only used to print the circuit design onto the conductive fabric. You will then have to hand paint a clear resist over the inkjet image before the circuit can be etched.
See step 1 for details on a printer that may work to directly print the resist onto conductive fabric.
Alternately--an inkjet printer is not necessary--you can just freehand paint or draw on the resist where you want the conductive traces to be.
Pic 1 shows a simple circuit that that lights 3 LEDs. I made some of the traces circular to find out if they would conduct well at angles to the warp and weft of the fabric.
Materials
Performix (tm) liquid tape, black-Available at Wal-Mart or http://www.thetapeworks.com/liquid-tape.htm
Carbon Graphite, fine powder- Available in larger quantities at http://www.elementalscientific.net/
Available in smaller quantities at your local hardware store. It's called lubricating graphite and comes in small tubes or bottles.
Conductive thread-Available in small spools at: http://members.shaw.ca/ubik/thread/order.html
or at: http://www.sparkfun.com/commerce/categories.php?cPath=2_135
Conductive fabrics available from: http://www.lessemf.com/fabric.html
Clear Nail Polish
Crayons
Ferric Chloride etchant available at: http://www.allelectronics.com/cgi-bin/item/ER-3/445/DRY_CONCENTRATED_ETCHANT_.html
or at: http://www.circuitspecialists.com/search.itml?icQuery=ferric+chloride
Inkjet printer
toluol solvent-available at hardware stores
wax paper
Pic 2 shows the three conductive fabrics that were used in this instructable.
1-VeilShield-A mesh polyester plated with a blackened copper. Very light and 70% transparent.
2-FlecTron-copper plated nylon ripstop.
3-Nickel Mesh-Semi-transparent copper and nickel coated polyester.
pic 3 shows the back of the circuit and the glued components.
Step 1Print The Circuit Pattern With An Inkjet Printer
Create a black and white image in a drawing or image program that will be the pattern for your circuit. Print it out onto the center of a piece of copy paper and adjust the image size until you get the exact printed circuit size you are looking for. The final traces should be 1'/8" to 1/4" wide. Make them wider if you plan on carrying more than 100ma of current through them.
Next is to glue a square of conductive fabric onto the center of a standard piece of copy paper (pic 4). Clear nail polish works well as it dries thin and fast (about 5 minutes). Glue all the way across the top of the fabric (the side that feeds into the printer) and then put a blob of glue on the bottom of the fabric to keep it stretched tight.
Then, print the pattern of your circuit board (pic 5) onto the conductive fabric. Sometimes it takes a couple of passes to easily see the pattern on the fabric.
An Experiment That Failed
I originally tried to directly print on the resist with an inkjet printer. I printed the pattern seven times on the front and then seven times on the back to make sure the fabric was well saturated with ink. Unfortunately the ink in my printer (a Canon Pixma MP500) was too porous or not waterproof enough to work as a resist. Perhaps there is some brand of inkjet printer that has an ink that would work.
Wax is very hydrophobic. As you can see in the next step, even wax crayons can be used as resist on conductive fabrics. So, one good possibility for printing resist directly onto the fabric, is a Xerox Phaser or Tektronix Phaser printer that uses a melted wax ink. This very good instructable http://www.instructables.com/id/DIY-Flexible-Printed-Circuits/ by ckharnett shows how he used such a printer to print wax ink resist on special copper-clad polyimide plastic sheet to create flexible circuits. These are expensive, hard to find business printers, but if you can get access to one, it may just work to directly print resist onto conductive fabrics.
34 comments
Dec 17, 2011. 7:46 AMRevanchist says:
Truly magnificent! All it needs now is a way to avoid getting the components wet, but the shirt washed and we're in business! ... Well I mean washed because regardless of the coolness of the shirt, it'll eventually stink after a week no?
Truly marvelous! I'll add this to the list of DIY projects I want to try, Thanks
Feb 14, 2008. 6:43 PMWard_Nox says:
combined w todays news of fabric that generates electricity this has potential
Jul 26, 2011. 11:04 AMbdaugherty says:
http://en.wikipedia.org/wiki/Thermoelectric_effect shows a device that if you were to keep one side warm (against your wrist for example) and the other exposed to a cooler temperature (surrounding air) that it will generate an electrical charge. :)
Feb 21, 2008. 10:26 PMadamvan2000 says:
You read about that too, eh? That's so cool. Now all they have to do is make enough to make a full article of clothing. ~adamvan2000
Feb 21, 2008. 2:56 AMzetacool says:
I wanna stamp my iPod onto my t-shirt. Cos I always forget my iPod and I always use the same T-shirt (yes, thats why I don´t have a girlfriend)
Feb 21, 2008. 4:10 PMKlappstuhl says:
Why didn't anyone think of a fabric mp3 player anyway? It seems rather logical that it would sell quite good.
May 18, 2009. 7:56 PMTheDodgyLodger says:
I'm still waiting for a fabric cell phone that I can velcro to my shoulder.
Nov 20, 2010. 9:10 AMbeehard44 says:
there is a fabric phone that can be bent and still works. i forgot where i saw it
Apr 1, 2009. 6:29 PMgamewinners42 says:
wait a second...... Did you make a lighted piece of cloth with the Marathon symbol on it? epically awesome.
Oct 30, 2008. 3:29 PMCarlos Marmo says:
Wonderful Work! Congratulations!
Jul 9, 2008. 7:22 AMGjdj3 says:
Wow, this is a cool instructable also! I didn't know that this could be done at home. Really nice job.
Feb 22, 2008. 3:00 AMEdgar says:
Fantastic!
Feb 21, 2008. 6:16 PMxenobiologista says:
My biomedical engineer boyfriend got all excited when I showed him this, then he was like "Oh...it's not medical grade material." (need to use for brain implants =D
Feb 19, 2008. 9:56 AMrobbtoberfest says:
So, so sweet! I want to make a motherboard on my t-shirt and the rest of the components on my jeans.
Feb 21, 2008. 5:44 PMzawmintu says:
rofl planning to integrate a oled screen too? (what about cooling? or is it just going to be hot hot hot? )
Feb 21, 2008. 4:36 PMGitarGr8 says:
Sounds like a good way to fry your floppy...
Feb 21, 2008. 6:01 PMmisanthrope13 says:
I use solid state.
Feb 20, 2008. 11:27 AMhypermechanic says:
Watch your resistance carefully.
Sep 22, 2010. 2:53 PMthreefer says:
Resistance is futile!
Nov 13, 2008. 12:36 PMrivetgeek says:
resistance is useless.
Feb 22, 2008. 1:21 AMhypermechanic says:
Yes, combustibility needs to be address for safety reasons. To much current on this cloth and it may burst in to flames. Though there is an Idea for a electric fuse for say fireworks. This should be used with very small amounts of current. If you need to see an example I think a piece of stripped speaker wire on a car battery would do it. Be careful. The red light followed by the puff of smoke or if you have ever seen an extension cable burst in to flames. If I remember correctly this is nylon fiber for the instructable, that will melt and burn. If you do toast your project please use proper ventilation burning plastic is toxic.
Feb 20, 2008. 10:01 PMdarkmuskrat says:
lol, is that a capacitor or are you just happy to see me?
Feb 21, 2008. 4:47 PMwaterppk says:
Boy, the inductor sure keeps the current flowing!
Feb 21, 2008. 6:15 PMadamvan2000 says:
I have to say it. I've got a 3 and a half floppy and a 5 and a quarter hard drive. :0P ~adamvan2000
Feb 21, 2008. 5:04 PMPolymorph says:
Very cool!
Your direct inkjet print didn't work because the ink is wrong. Volkan and Stefan on the Homebrew_PCBsHomebrew_PCBs list figured out that Epson Durabrite or 3rd party pigmented ink will work as etch resist, but only if it is baked before etching.
Full disclosure: I'm owner of that group.
Feb 19, 2008. 7:24 PMbowmaster says:
This will come in handy when I am constructing my prototype Ninja suit.
Feb 15, 2008. 5:25 AMfashiongeek says:
What an amazing instruction - the BEST EVER I have seen for textile electronic which I am a BIG fanBIG fan off.
I do have one question: does the etching damage or weaken the fabric, make it brittle or easy to tear?
Feb 19, 2008. 4:39 PMwompastompa says:
how difficult would it be to incorporate this into a standard shirt? perhaps there could be a method of attaching it to where it could easily be removed (as laundering a circuit board seems like a negative action to take : D )
Feb 19, 2008. 7:23 PMzoundsPadang says:
I;m sure you could spray a protective layer onto it. As long as you remove power sources and treat it as a delicate piece of clothing I'd be willing to bet you could safely wash it.
Feb 19, 2008. 3:43 PMthinguy says:
I want to make a T shirt that says Hi
Feb 19, 2008. 2:46 PMbob31415 says:
Hi I'm from Ecuador. Your instructable is very funny! LOL!!!!
Feb 14, 2008. 6:24 PMwestfw says:
So you can etch the conductive coating off of the conductive fabrics? That's very cool... When you're rinsing your etched fabric, don't forget to use LOTS of extra water to avoid having your drain pipes become the next thing to be etched.
Feb 14, 2008. 3:07 PMGorillazMiko says:
This is SO cool! All your Instructables are awesome! And that robot thing, is that a helping hands robot? Really cool Instructable as always.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
387
Author:mikey77
I believe that the purpose of life is to learn how to do our best and not give in to the weaker way.
