Step 7Conductive Glue and Sew a Picaxe Microcontroller Circuit
Picaxe chips and programming cables and software are available from: http://www.hvwtech.com/default.asp
Or: http://www.futurlec.com/Components.shtml
A very good manual on programming the Picaxe in Basic is available free from: http://www.rev-ed.co.uk/picaxe/
In this particular project, the 18x Picaxe is programmed to light the 3 by 5 led matrix in a sequence of letters or numbers to spell out messages. By varying the input voltage to an ADC (analog to digital converter) input, the potentiometer (see step 3) made out of flexible conductive fabric, is used to choose different messages. It becomes effectively, a one input multi-switch.
I originally glued in dropping resistors R1-R5 in order to make sure I did not overload the Picaxe outputs. It turned out that the combination of glue joints and conductive thread created enough resistance that the resistors were unnecessary. So, I shorted them out on the back with conductive thread.
The four pin socket was to be for power in and serial programming. It did not work out well as there was not enough room to sew and glue the thread on adequately. The connections eventually came loose with use. In the future, I would solder some short wires on first and splay them out to have more room to glue.
I ran out of time, so I was unable to install a glued battery pack below the Picaxe chip as I had originally planned.
I chose to glue the whole circuit and avoid soldering just to see if I could work out the techniques required. But, it is no doubt faster to solder rather than to glue up the basic connections of a micro controller. A more practical method for future projects would be to solder the Picaxe chip, batteries, plugs, and most of the resistors on a long narrow circuit board. The board would be the width that you want the circuit to fold up at. The thread would then be run to the input switches, potentiometers, or other sensors and the outputs to the LEDs to make the circuit flexible. I have seen several commercial products that roll up done in this way.
If you want to make the circuit more rugged, I would suggest coating all of the IC pins and any other delicate conductive glue joints with clear contact cement so that they are solidly attached to the fabric.
You can download the Basic program code for the Picaxe at: http://www.inklesspress.com/rollupcircuit.txt
For other possible circuits to try that use the Picaxe, you can check out some other projects I have done at: http://www.inklesspress.com/picaxe_projects.htm
The Possibilities of Using Flexible Circuits
I have just begun to explore the possibilities of flexible circuits using conductive materials. You may not want to build a circuit that completely rolls up. But the techniques presented here show how you can make circuits on any flexible material including hats, paper, pants, rubber, T-shirts, gloves, socks, wallets, inflatables, or jackets. You can also make flexible sensors and displays of various kinds. The limit--is your imagination.
comment
Add Comment
Add Comment
