Conductive Play-Dough Flying Saucers
2,652
18
5
Posted in TechnologyElectronics
Introduction: Conductive Play-Dough Flying Saucers
Easy to make 'Flying Saucers' based on home-made conductive play-dough 'Squishy Circuits'.
“Squishy circuits are a project from the Playful Learning Lab at the University of St. Thomas. The goal of the project is to design tools and activities which allow kids of all ages to create circuits and explore electronics using play dough.”
http://courseweb.stthomas.edu/apthomas/SquishyCircuits/
Step 1: What You Will Need
  • Conductive play-dough (see below)
  • 5mm red LEDs (Light Emitting Diodes). Approximately eight per saucer
  • PP3 battery
  • PP3 battery clip
  • 3 inch wooden disc (available from craft shops).
You can make your own conductive play-dough using the recipe published by the University of St Thomas. Regular play-dough that can be bought in the shops is also conductive but not as much as the recipe below.
Conductive Dough Recipe: Makes approximately 500g play-dough
  • 1 cup water
  • 11⁄2 cups of flour (hold back 1/2 cup for kneading)
  • 1⁄4 cup of salt
  • 3 tbsp. Cream of Tartar or 9 tbsp. lemon juice
  • 1 tbsp. vegetable oil
  • food colouring
Source: http://courseweb.stthomas.edu/apthomas/SquishyCircuits/conductiveDough.htm
Start by mixing together the solid ingredients (remember to hold back 1/2 cup flour), then the oil, then add the water gradually while stirring. This seems to be the best way to avoid lumps. The Cream of Tartar is the 'active' ingredient that increases conductivity. Add colouring (optional) then knead on a board with the remaining flour as required to get the right consistency. It will stay fresh in the fridge wrapped in film for a couple of weeks.
Step 2: Roll Out Two Play-dough Balls
Roll out two play-dough balls about 1 and a half inches diameter. These are going to be connected to the positive and negative sides of the battery and will be separated by the insulating disc.
Step 3: Squish the Ball Onto the Disc
Squish the ball onto the disc, cupping it in your hand to form a dome. This will be the underside of the flying saucer.
Step 4: Seal the Battery
We'll use a 9V (PP3) battery. Clip on the battery connector. The battery is going to be buried in the play-dough so first we need to seal the terminals with some masking tape to prevent the play-dough oozing in and creating a short-circuit.
Step 5: Place the Battery on Top
Turn the saucer over and place the battery on top. The play-dough should be sticky enough to hold it in place.
Step 6: Cover the Battery
Use the second ball of play-dough to cover the battery. Gently cup the dough to create a dome-shaped top to your saucer. Make sure the two sides of the saucer aren't in direct contact.
Step 7: Add an LED
Insert the exposed ends of the battery leads into each side of the play-dough. Add an LED to test the circuit. Splay out the legs of the LED slightly and push the legs into the dough, one with side of the wooden disc. As a diode they'll only work one way around (the shortest leg is the cathode that should be connected to the negative battery terminal). The LED should light up. It's OK to experiment - it won't break the LED.
Avoid connecting the LEDs directly to the battery terminals as this may release the magic smoke. The play-dough functions as a resistor that lowers the voltage across the LED.
Step 8: Add the Rest of the LEDs
Arrange the LEDs around the circumference of the flying saucer. Remember that the LEDs are small parts with sharp legs so the flying saucer should be assembled under adult supervision. The LEDs can be turned off, or made to 'flash' simply by removing one of the battery leads.
Step 9: Squishy Saucers
You're now ready to enact a squishy visitation of the flying saucers. Use the rest of the dough to make some squishy alien occupants.
    • Space Challenge
      Space Challenge
    • Science of Cooking
      Science of Cooking
    • Spotless Contest
      Spotless Contest
    5 Comments
    My children had so much fun making these. Being young boys they have so many questions about how lights work, why a battery makes their toys work etc. This was an amazingly simple, fun and safe way to show them. And because they'd built them themselves - they played with the UFOs for days. Genius!
    Oh, and the electricity questions have stopped for now - bonus. Thanks Steve!!!
    Never heard of conductive play dough. This is interesting. Is there a reason for the pliable conductor?
    I use it for teaching kids mainly because it's so easy to make connections, avoiding the need for soldering or fiddly plugs. I've also used conductive play-dough recently for teaching logic <http://www.slideshare.net/stevebattle/squishy-logic>
    Wow that looks like such fun! The flying saucer looks so great in the end, and conductive play-dough has so many fun possibilities! Welcome to instructables!
    Thanks so much for your support. My Niece's children (aged 3 & 4) did need help to shape the play-dough but they really were able to add the LEDs by themselves. I don't know of a more accessible technology for kids.
