Introduction: Confetti Egg
Confetti eggs are fun for Easter. You can ethier throw them or break them on each others head. Lets get started. If you vote you are cooler than Chuck Norris.
Step 1: Materials
Eggs
Container
Needle or thumbtack
Glue
Confetti I used colored school paper cut in up
Sink egg carton
Soap
Tissue Papet
Step 2: Cutting Out the Guts!
You must poke a hole in the top of the egg with a needle and 1 bigger hold at the other end. The big hole shold be dime size. At the small hole clean it off and blow the guts into a container.
Step 3: Clean the Egg
Rinse out the egg with soap but be careful. If you are to rough then the egg will ethier crack or break. If the egg did break you can rub glue over the spot.
Step 4: Let the Egg Drie
Now that the egg is cleaned you have to let it drie. I usually let it set for 24 hours. Make sure to leave it away from where they could fall,crack or even break. I just put the eggs back in the carton.
Step 5: Egg Confetti
Now the eggs have dried so now we are able to put the confetti in. I used old colored school paper cut into scraps. I recycle this way. First, put the confetti in the egg carefully. Then glue around the big hole carefully. Put on a quatar size piece of tissue. Then glue tissue down again.
Step 6: Coloring the Egg
You can color the egg but I decided not too because of a time crunch. Now you can go and go Rambo on your friends or be a ninja and sneak up on them. Be carefully because I won't take responsibility.
Egg Contest
