Configure Password for Devices in Cisco Packet Tracer
Published
Introduction: Configure Password for Devices in Cisco Packet Tracer
About: I am a engineering student.
In this instructable you will learn how to set a password to layer 2 and layer 3 devices so that only the user can access them.
En este instructable se aprenderá a poder colocar una contraseña a los dispositivos de capa 2 y capa 3 para que solamente el usuario pueda acceder a ellos.
Step 1: Privileged Mode
In this step we will configure the user mode in a privileged mode. To do this we select our router and enter the CLI configuration by placing the following command:
Router>enable
En este paso configuraremos de modo usuario a modo privilegiado. Para ello seleccionaremos nuestro router y entramos a la configuración CLI colocando el siguiente comando:
Router>enable
Step 2: Global Configuration Mode
Now we configure from privileged mode to global mode, the commands to use are:
Router#configure terminal
Ahora configuramos del modo privilegiado al modo global, los comandos a utilizar son:
Step 3: Set the Password
To configure the password it is essential to do so in global configuration mode, the commands that will be used are:
Router(config)#line vty 0 4
Router(config-line)#password instructables
Router(config-line)#login
Para configurar la contraseña es indispensable hacerlo en el modo de configuración global, los comandos que se utilizarán son:
Step 4: Enable the Password
Now that the password has been set, it is essential to be able to enable it in the global configuration, the commands to use are:
Router(config-line)#exit
Router(config)#enable secret instructables
Ahora que ya se configuro la contraseña es indispensable poderla habilitar en la configuración global, los comandos a utilizar son:
Step 5: Test Password
To do this we will try to enter each configuration mode, see that if we do not have the password we will not be able to access the global configuration mode and the privileged mode.
Para ello intentaremos ingresar a cada modo de configuración, veremos que si no tenemos la contraseña no podremos acceder al modo usuario y al modo privilegiado.
Step 6: Remote Console Cable Access
Now we will try to access the router via a laptop using a console cable and serial communication.
Ahora intentaremos ingresar por medio de una laptop al router usando un cable de consola y comunicación serial.
Step 7: Telnet Remote Access
As a last test we will give an IP address to a laptop and a physical interface of the router, we will try to log in from the laptop via telnet to the router. Now we will notice that at this time you will ask us for the password twice, once to enter the user mode and again to enter the privileged user.
The network address 192.168.255.0 /30 will be used for this purpose.
Como última prueba le daremos una dirección IP a una laptop y a una interfaz física del router, nosotros trataremos de ingresar desde la laptop por telnet hacia el router. Ahora notaremos que en este momento nos solicitara dos veces la contraseña, una vez para ingresar al modo usuario y otra vez para ingresar al usuario privilegiado.
Para ello se utilizará la dirección de red 192.168.255.0 /30
Step 8: Configure and Enable Password on a Switch
For demonstration purposes only, we will also configure the security password for the switch of our topology with the same commands we use for the router described in steps 3 and 4. Plus the safety test from step 6.
Solo como fines demostrativos, también configuraremos la contraseña de seguridad para el switch de nuestra topología con los mismos comandos que usamos para el router descritos en los pasos 3 y 4. Además de la prueba de seguridad del paso 6.
    • Clocks Contest
      Clocks Contest
    • Woodworking Contest
      Woodworking Contest
    • Planter Challenge
      Planter Challenge
