Configure VLAN in Cisco Packet Tracer
Published
Introduction: Configure VLAN in Cisco Packet Tracer
About: I am a engineering student.
In this instructable will explain how to configure vlans on the switches. Vlans only works on Layer 2.
Configurar VLAN en Cisco Packet Tracer
En este instuctable se explicará como configurar por medio de comandos las vlans para los switches. Hay que tomar en consideración de que las vlans funcionan únicamente para capa 2.
Step 1: Place
Step 1: Place and connect the devices.
Paso 1: Colocar y conectar los equipos.
Step 2: Configure Vlans on All Switches
Step 2: Configure vlans on all switches. To do this, the following commands will be used in global configuration:
Vlan 10
Name RED
Exit
Vlan 20
Name BLUE
Exit
Vlan 30
Name GREEN
Exit
Paso 2: Configurar las vlans en todos los switches. Para ello se utilizarán los siguientes comandos en configuración global:
Vlan 10
Name RED
Exit
Vlan 20
Name BLUE
Exit
Vlan 30
Name GREEN
Exit
Step 3: Configure the Trunk Mode
Step 3: Now configure the mode trunk to all interfaces of the switches that connect to another switch. The commands are:
Int Fa0/24
Switchport mode trunk
Switchport nonegotiate
Int Fa0/23
Exit
Paso 3: Ahora hay que configurar el modo troncal a todas las interfaces de los switches que estén conectadas hacia otro switch. Los comandos son:
Int Fa0/24
Int Fa0/23
Exit
Step 4: Configured in Access Mode
Step 4: In this step will be configured in access mode to all the interfaces of the switches that are connected to end devices such as laptops, you must be careful since in this step will be allowed the access of a single vlan per interface. The commands are:
Int fa0/1
Switchport mode access
Switchport access vlan 10
Int fa0/2
Switchport access vlan 20
Int fa0/3
Switchport access vlan 30
Do write memory
Paso 4: En este paso se configurara en modo acceso a todas las interfaces de los switchs que estén conectadas a dispositivos finales como las laptops, hay que tener cuidado ya que en este paso se permitirá el acceso de una sola vlan por cada interfaz. Los comandos son:
Int fa0/1
Int fa0/2
Int fa0/3
Do write memory
Step 5: Configure the IP Address and Subnet Mask
Step 5: As a next step we must configure the IP address and Subnet Mask for each laptop, there are no layer 3 devices on the network so the default gateway will not be configured. As a demonstration purpose these will be the network addresses that we will use for each vlan.
VLAN 10 192.168.10.0 /24
VLAN 20 192.168.20.0 /24
VLAN 30 192.168.30.0 /24
Paso 5: Como siguiente paso debemos de configurar la dirección IP y la Subnet Mask para cada laptop, como no hay dispositivos de capa 3 no se configurará la puerta de enlace predeterminada. Como fin demostrativo estas serán las direcciones de red que utilizaremos para cada vlan.
Step 6: Communication in the Same Vlan
Step 6: To verify that this configuration is correct, we will verify that the laptops that are in the same vlan have communication. A ping test will be done.
Paso 6: Para corroborar de que este bien la configuración comprobaremos de que las laptops que están en una misma vlan tengan comunicación. Se realizará una serie de ping.
Step 7: No Communication in Different Vlan
Step 7: Finally it will be verified the most important, that there is no communication between final devices that are in different vlans. Like step 6 a ping between the laptops will be made.
Paso 7: Para finalizar se comprobará lo más importante, que no haya comunicación entre dispositivos finales que estén en distintas vlans. Al igual que el paso 6 se realizaran un ping entre las laptops.
    • Make it Move Contest
    • Oil Contest
      Oil Contest
    • Clocks Contest
      Clocks Contest
