3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Connect an MP3 player to a tape player
How to connect an mp3 player, or other stereo source, to a tape player in order to listen to the music.
Step 1Materials
For this proyect you will need the following tools:
-A soldering iron
-A multimeter
-Headphones or stereo wires and plugs
-A tape player
64 comments
1-40 of 64next »
Dec 7, 2009. 8:46 AMCalcProgrammer1 says:
I did the same sort of thing to an old AM/FM/Tape Sony boombox I had, but instead of cutting into the tape head and destroying the tape player, I found  that it had a separate tuner board for the radio.  Looking at the cable connecting it, I found the ground, left, and right channels coming out of the tuner.  I spliced the left and right through a double-pole-double-throw toggle switch and also mounted an AUX input jack next to the headphones jack.  Now I can flip the switch to AUX to listen to mp3 player or computer (I also used it to play Xbox on my old TV) or flip it to Radio to use the radio.  Also, the amplifier for the tuner is designed for line-level whereas the amplifier for the tape is designed for a tape head, connecting to the tape head introduces more distortion whereas the tuner input sounds really clear.
Dec 27, 2011. 5:40 PMamclaussen says:
@pfmia: Connecting to a LINE level is the correct way to go... Radio tuner usually has close to line level; on the other side, the magnetic head has a much lower signal level, and it is NOT it´s only disadvantage: Magnetic Heads need a large equalization (like the old magnetic phono cartridges). THAT IS THE REASON connecting to the head will get distorted, badly equalized sound!!!
CalProgrammer1 has it ABSOLUTELY RIGHT!
It is WAY better to find Radio or Line level points in the circuit, in that way distortion is avoided (provided the cell phone or MP3 player volume control is NOT pushed too high), and a PROPER, flat equalization is obtained. Head level is too sensitive and not flat responding. Maybe tapping close to the VOLUME control of the boombox is an easier point to locate, in order to connect the pair of shielded cables to the switch and RCA input jacks (or the smaller 3 conductor 1/8" stereo jack, if you prefer. Best Wishes, Amclaussen.
May 28, 2011. 7:27 PMvalee8472 says:
How do you determine which are the right, left and ground channels if you don't have a schematic?
May 28, 2011. 10:05 PMCalcProgrammer1 says:
Ground should be easy, but beyond that you'll have to probe it. You can take a headphone speaker, tie one end to ground, and use the other end to find the audio signal. Once you find both signals, determining left from right should be easy (either play a tape recorded with only one channel or introduce a signal into one of the spliced wires and see what speaker the sound comes out of).
May 10, 2010. 3:31 PMWafous says:
 really nice, I may try this one
Jan 23, 2010. 5:56 AModysseusesperson says:
 i have a timex radio clock and i wanna hook the the cord into the amp not just the stero cus some of my songs arent loud so i wanna be able to turn it up on the ipod and the radio
Apr 10, 2009. 12:22 PMconty911 says:
hi ifound ur article and very interesting indeed, But i have 2 questions 1)when we connect the ipod/music player o/p directly to the head leads isn't it going to produce distortion as the input signal from ipod have considerable power where as magnetic head produces power in terms of uW (or signal voltage level of few millivolts) ,the distortiis casued by shifting of opearating point of PREAMP whic is conected immediately after the head unit. 2)like wise some people said using poteniometer will help reducing input signal ,but ifeel it wont be of much use....as they dont give clear demarcation of power limits. What if we solder the input after the preamplifier stage or at the input pins of Amplifier IC of the cassette player??? having tried the given method at my car stereo it aint did good ,plz let me know if something better comes in anybody's mind.thanks
Jun 30, 2008. 5:41 AMjabujavi says:
seeemooos los delinqúentess... los vi ace dos dias en paiporta, valencia... por cierto podrias explicar como conectar el mp3
Feb 29, 2008. 8:07 PMreko says:
pfmia, thank you very much for the instruction. I followed your guide, and it worked ! but my problem is : distorted sound. 1. if i turn-down at lowest volume on the cell, and turn-up my car stereo volume, i got a very noticable hiss sound noise, and the distorted music still there but reduced. 2. if i put 1/3 volume on my cell, then the hiss reduced, but more music distorted. 3. if i put more than 1/2 volume on my cell, then i got a completely distorted music. 4. if i feed the cassette, but not plug the male cable to my cell, turn-up volume on car stereo and then touch the body cable, i hear "dep" from the speaker. what did i do wrong ? i just wonder, is there anyway i can do to normalize all this hiss and distorted sound ? is putting a stereo potentiometer / resistor on the cable will solve ? but i don't know the suitable size of the resistor. anykind of respond will be greatly appreciated, and i'm sorry for my broken english as i'm from asia country and i'm sorry too if this is not the right place to put my question. anykind of respond will be greatly appreciated, thank you in advanced.
May 18, 2008. 1:53 AMm-arijn says:
If you mean your mobile phone with cell, then the noise comes of the radiation of your mobile phone. When you put it next to an amplifier you will hear the same noise..
Jul 16, 2008. 6:21 PMAustinisi says:
You put the potentiometer in series with...the mp3 player and head of the cassette player? if i'm using audio cables (left and right), do i buy two potentiometers?
Jul 17, 2008. 7:49 PMAustinisi says:
I attached the two potentiometers like you said. When I attached the ground to the potentiometer, a lot of the distortion went away, but the a little static/hum remains. Any other ideas?
Jul 16, 2008. 6:25 PMAustinisi says:
also, how important is it to used the ground between the mp3 player and the circuit board?
Mar 1, 2008. 11:59 PMreko says:
thank you - thank you very much indeed. i'm very happy to receive your reply, and your kind information. i will tell you my result as soon as i have tried your suggestion to put the potentio/resistor into the stereo cable. it's not the tip naked cable that i tap, but the cable body which is coated which make sound. so i will also check the solder joints and the grounding connection. i really appreciate your time to enlighten me. thank you once again !
Mar 4, 2008. 7:11 PMreko says:
hi pfmia, it works - it works ! i follow your instruction : "the smaller K-size potentio you can find" so put a 10K potentio between head-unit to the mp3 player connection, and the result : no hiss - no distorted music ! i'm happy now...:-) thank you very much for your kind reply and your great instruction. regards, reko
Mar 2, 2008. 8:06 PMreko says:
ok, i will. but i think it will be still more a few days from now, as my mom use the car quite often recently...:-) thank you.
Mar 30, 2008. 3:54 PMcomputerwiz_222 says:
You can also simply go spend a dollar on a cassette to 3.5 mm adapter. Saves you much grief and you can now still play tapes... Who the hell still has a tape deck in their car lmao.... I took mine out and put in one of those in dash el cheapo DVD multifunction things. Works great but is a real peace of crap... (it was only $150 and it pumps 50 watts X 4.) The best feature is the USB port that it has, I can now listen to my music through my ipod or whatever..
May 3, 2008. 6:53 PMrelentless says:
yeah i run my ipod through a tape adapter to. For all thoughs who want to know how its simple. Buy a 3.5mm adapter as computerwiz_222 said (it should look like a tape casset with a wire running from it with a headphone jack at the end of the wire) then simply put the tape into the tape deck, plug the jack at the end of the wire into your mp3 player where the headphones normaly go and then press play on the tape deck and play on the mp3 player. Simple as that, hope it helped people ! Relentless.
May 3, 2008. 6:08 PMdlfynrdr says:
I'm a bit confused On my head (insert crude joke here) there is also a fourth yellow wire. Where does that go? Can somebody help now that I've turned my radio into a jigsaw puzzle?
Jun 15, 2007. 9:31 AMjridley says:
To do this properly you REALLY should either put a resistor in line with it, or trace the circuit and find the actual line-level spot to tap the circuit board. 'Course, that can be tough to find sometimes. What this is doing is feeding a line level (or higher) input into a preamp. You're risking damage to the preamp.
Aug 23, 2007. 6:12 AMspacessj says:
how can I identify this spot(I have the service manual of the fw330)
Aug 23, 2007. 7:21 AMjridley says:
You need to poke around after the preamp. Take a look at the schematic of the player; there should be an amplifier of some kind that the tape head leads into, and then a line out of that and into the main amplifier. I haven't looked at any really new players; it's possible that newer players just have one big chip that does everything, and if that's the case, unless there's an unused line in pin on the chip (likely, actually) that you can make live (maybe less likely) then you'll have to use the method outlined here.
Aug 24, 2007. 3:38 AMspacessj says:
The Tape idea didn't work. apperently I had to keep the tape deck connected for it to work. I used the AUX instead.
Aug 24, 2007. 3:47 AMjridley says:
Well, yeah, if you have an aux input then this whole thing is pointless, just use that. The whole point of this instructables was for people who do NOT have an aux input.
Aug 25, 2007. 4:07 AMspacessj says:
My original plan was to keep the AUX free. That's why I wanted to use it on the tape
Aug 23, 2007. 5:37 AMspacessj says:
Heh I just hacked a phillips mini hi-fi system(fw330) and tossed away the cd(was broken) and tape players. Thanks to this instructable it's still usefull. Only two problems: A the speakers are from an other system and are 4Ohm versus the 6 Ohm out on the amp and the speakers are only 5W and it's a 15w amp
Aug 3, 2007. 9:32 PMkillerjackalope says:
lol if your in the UK I suggest the tesco headphone to tape adapter I picked mine up for £1 but they're £3 really i just swappied a nearby label cos i only had a quid on me and wanted it for the car ride home but you could try skipping the pre-amp and using the cables for the the amp, rip the lot out of the bulky casing and be creative I stealthed my stereo in a locker from ikea but how about an empty beer crate remember style has it's merits also anything with circuits everywhere has a far lower chance of being stolen like my broken prtable DVD player whic i hacksawed into a tiny CD player
Jul 4, 2007. 9:19 AMbabyboi512 says:
for easi use...use a 3.5mm jack to cassete u can get it for 5$
Mar 15, 2007. 10:30 PMSpartan 117 says:
You all do relise that all you have to do is hook it(MP3 player) up to the analog or aux adaptor? ill do an instructable when im bothered, oh and you can also use the analog method as a batery powered amp for a guitar or bass etc.not great but usefull
Mar 20, 2007. 1:50 AMSpartan 117 says:
most stereos do ive no actually seen one without it before but if it doesnt then open it up and find the amplifieng input and hoof it up that way i suppose
Jun 15, 2007. 9:29 AMjridley says:
I have 3 boxes and NONE have aux input. It's only been common in the last 3 to 5 years, really.
May 28, 2007. 9:37 AMkishida says:
The older or cheaper boom boxes do not have aux input
1-40 of 64next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:pfmia
