Step 4Locate where the magnetic head connects to the board
To identify what pin connects to each wire you can use your multimeter, by checking the continuity of the connections. I'ts usually represented by a diode in your multimeter.
Put a tip on where the wire connects to the head, then put the other tip in the connector. When it beeps the wire where you have put one tip connects to the point of the circuit where you have put the other.
comment
Add Comment
Add Comment
