3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Connect an Xbox 360 to Wireless without an official Adapter
This Instructable shows you how to connect your 360 to a laptop that has wireless access to get internet on your 360 anywhere that you can receive wireless internet.
NOTE: YOU MUST HAVE WIRELESS INTERNET ON YOUR LAPTOP BEFORE THIS WILL WORK.
Step 1THE FIRST STEP -find your network list-
First you need to Click Start->control panel-> Network Connections
125 comments
1-40 of 125next »
Jan 22, 2012. 3:48 PMmancer67 says:
im going to try to hook it up from my computer to my xbox 360
Mar 15, 2011. 4:17 PMawascher says:
i have a new 360 and it as a wireless thing inside of it and it will not let me conecte to my belkin n router at all does anyone know how to fix that
Nov 5, 2011. 6:21 AMcurtisx11 says:
i tried this on my laptop and i have windows 7 .. it did not work either.....would not connect... send help fast...
Jun 18, 2011. 12:03 PMJacmanPones says:
Bro! After all of these years, this finally worked. Simple and effective steps! Thanks a miL!
-Pones
Sep 19, 2010. 5:01 AManimaonline says:
Use OpenDNS it's always working.
http://www.opendns.com/
Even if the one provided by your ISP goes down.
Primary DNS: 208.67.222.222
Secondary DNS: 208.67.220.220
Aug 2, 2010. 11:48 AMJuniorRawr says:
Help me I followed all your step and I still can't connect to xbox live. This is what Test Status Xbox 360 X Network . . . . . Internet . . . . . Xbox Live Please help ASAP
Jun 28, 2010. 11:46 AMDrWeird117 says:
This isn't technically wireless. Wireless would be if you used the Wireless Adapter.
Mar 30, 2010. 11:45 AMswimmer95 says:
will this work if you have a mac?
Jun 13, 2010. 8:37 AMapplereviewguy says:
nope.
Feb 27, 2010. 7:42 AMkillersquirel11 says:
for XP Pro or Vista Home Premium (and whatever equivalent for 7) ICS can be configured by going into network connections, right clicking on the wireless, clicking properties, clicking the sharing tab, then clicking the allow other computers to connect through this one button, then selecting the ethernet connection from the drop down list, then hitting OK.
Feb 23, 2010. 9:21 AMdaveazar says:
You can connect to xbox live using this method but i personally wouldn't recomend it.
i've gone through about 12 -15 (wasn't really counting)  xbox's since i bought my 1st console 2nd hand a few of them stopped working for other reasons but l went through the most of them when i shared my laptops internet connection through xp.
I connected in this way for approximatly 3-4 months when i was connected in this way i went through around 8 -10 most of which had the same error i can't remember the exact code but console displayed 3 red lights and error message i asked guy at the store were a kept returning my consoles and he said the error was to do with hardware failure on the ethernet port.
I kept getting newer consoles which also broke the one i have now is one that i had previously returned but having been repaired shortly after recieving this console i stopped connecting through my laptop and i've had this one for at least without and problems.
I would risk this if you don't have a guarantee on your xbox i was lucky that with store i bought my console from i could just go a swap it for another there and then with out having to send it off.
Feb 17, 2010. 11:28 AMHolbrook15 says:
I'm using the connection it works. BUT everytime I play, the server times like every two minutes. Does anyone know how to fix this? or what would cause this? Because the connection is always excellent or very good. HELP PLEASE!!! and also i'm connected to xbox live but is there a reason y it says that the wireless connectiuon is not connected?
Jan 1, 2010. 3:45 PMmattrlc00 says:
i got it to work and it would keep going even when i close my laptop and then i unplugged it from my laptop for a minute and then later plugged it back in....now i cant even let it go to screen-saver without it disconnecting from live. Anyone know why it is doing this and how it can be fixed? thanks
Dec 31, 2009. 8:36 PMkal1fornia says:
hey it has to be a crossover ethernet cable correct....?
thanks
Dec 18, 2009. 2:35 PMjufreese says:
your wireless and lan both have to be enabled and disconnected for you to be able to bride them
Aug 14, 2008. 9:22 PMmeesarjarjar says:
Can someone please help me this is extremely frustrating. I followed all the steps but when I test it IP fails. Wireless Network is greyed out (is it supposed to be?) For some reason when i bridge my wireless to my LAN the wireless stops working, and when i remove it from the bridge it starts working again. Could someone please help?
Aug 16, 2009. 10:38 AMdelphi says:
your wireless connection is supposed to be grayed out...your using a bridge to your laptop through an ethernet cable so if you passed the ethernet connection test then it should be fine
Dec 25, 2008. 6:33 PMtikka786 says:
Hey Guys This Tutorial Is Not As Good As The One I Found, I Had Mine Hooked Up After A While. It Took Me A Decade... Ok Im Joking :D But it took me a long time!
But here Is the link for you
http://www.se7ensins.com/forums/bridging-tutorials/23255-ics-bridging-laptop-wireless-bridging-using-command-prompt.html
This Way Is Alot Better! Please Comment Here Thanks!
P.S: For Those Having Problems Opening Command Prompt. Open Via Start> All Programs> Accesories> Command Prompt :)
Thank U
Dec 22, 2008. 5:46 PMhoodlum3 says:
When you are on a laptop you can only be on Live or on the internet but not both at the same time.
Dec 6, 2008. 1:37 PMimlqqn4her69 says:
did some1 one help u? im having exact same problem
Jun 26, 2009. 7:36 AMdaelans says:
do you need an extra router for this to work?
Jun 30, 2009. 2:34 AMShadowfury says:
You need 1 router and 1 laptop with a wireless connection to that router. So no, you do not need an extra router.
Feb 21, 2009. 6:11 AMpete-d-jedi says:
Hi, I have a desktop PC upstairs that is wireless capable but is hooked up to a wired modem. My Xbox 360 is downstairs next to the tv, I have a new wireless netgear router that I was wondering if I could just hook that up to my xbox downstairs and keep the pc wired upstairs, as I know that most my friends have their 360's plugged straight into the wireless router. Can I have both wired upstairs and wireless plugged in the back of XBOX? If so how
Jun 28, 2009. 2:47 PMlytlboiblu says:
what i would suggest is to connect the xbox to the router wired and the pc to the router via wifi. then do the enable internet connection sharing on the Pc wired, selecting the wireless as the network to share to. not sure if just bridging them will work in this case or not. hope this helps
Feb 25, 2009. 10:05 PMjbuggin says:
when i select both then rt click, there isn't an option for me to bridge the connection. I wanna play my 360 online tonight. pls get back at me.
Jun 17, 2009. 1:02 PMMilkCarton says:
i have the birdge connection but it is still not working
May 25, 2009. 7:45 AMz3ddrocksz says:
if u go in your network connections and right click on the wireless one go to properties click on advanced and check off allow other network users to share this connection
May 10, 2009. 2:07 AMburnam09 says:
If your using vista and the message shows say you need at least 2 LAN or wireless connections follow these steps. Right click your connection symbol on the toolbar, and click network and sharing center. Then click the manage network connections on the left. Then right click LAN and go to properties. Click the sharing tab and make sure the first box is unchecked. You should be able to bridge now
May 8, 2009. 6:57 PMfwjs28 says:
this stuff is old, its been posted at least 10 times on here...be original.....
May 8, 2009. 3:46 PMChiiip says:
it just says for me, to create a network bridge, you must select at least two LAN ... that are not being used by the internet I'm confused, please help
May 8, 2009. 6:56 PMfwjs28 says:
lan port+wireless port +bridging= bridged connection
May 5, 2009. 3:03 PMNick Datilio says:
got it thanks alot!!!
Mar 11, 2008. 1:58 PMoutwestjake says:
Just a quick question, now when I disconnect the ethernet cord from the laptop, must I unbridge the connections? or do I just disconnect and connect it for next time?
Apr 11, 2009. 10:26 PMBeierlejk says:
Do I still need a Xbox live 3, 6, or 12 month card?
Apr 22, 2009. 5:09 PMgblax123 says:
Any will work
Apr 22, 2009. 11:07 AMbanananaman3579 says:
yes, this is a way to avoid buying a 100$ device that allows you to connect to the xbox servers through the internet, this system allows you to connect to the interet, not the xbox servers.
Jan 8, 2009. 6:43 PMphillip8222 says:
I have xbox 360 trying to connect to live threw my laptop threw vista I got them bridge every thin says its ruining rite but the xbox wont get an ip any suggestions
Feb 2, 2009. 11:16 AMC85 Vaio says:
manually put in your IP and DSN and everything.
1-40 of 125next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:Program
