Connect the Arduino and Make the Speaker Play
13,976
14
Posted in TechnologyArduino
Introduction: Connect the Arduino and Make the Speaker Play
To make your Arduino to play a melody you need thes accessories.
One 5 ohm speaker
One Arduino uno board
One Push buttom
One 10 kohm resistor
8 leds
And a lot of core wires
Step 1: Connect the Arduino and Make the Speaker Play
This is how i connected the arduino to the white connection plate.
With these picture should help you get an ide of how to connect the speaker to the arduino plate and make it play the basic melody that you will find in the arduinio program on you pc.
Check out http://arduino.cc/en/Tutorial/Tone if you need more info on how to connect.
Step 2: The Code
/* Original code created 21 Jan 2010
/ modified 30 Aug 2011
/ by Tom Igoe (http://pastebin.com/tCYvfky9) and configured by me 2013 (my code below)
/ When you firgure out how to connect the arduino and made it play the basic melody. You should start coding
/ First of you will need the notes you can copy paste mine or just copy it from http://arduino.cc/en/Tutorial/Tone
// we begin with definining all of the notes
#define NOTE_B0  31
#define NOTE_C1  33
#define NOTE_CS1 35
#define NOTE_D1  37
#define NOTE_DS1 39
#define NOTE_E1  41
#define NOTE_F1  44
#define NOTE_FS1 46
#define NOTE_G1  49
#define NOTE_GS1 52
#define NOTE_A1  55
#define NOTE_AS1 58
#define NOTE_B1  62
#define NOTE_C2  65
#define NOTE_CS2 69
#define NOTE_D2  73
#define NOTE_DS2 78
#define NOTE_E2  82
#define NOTE_F2  87
#define NOTE_FS2 93
#define NOTE_G2  98
#define NOTE_GS2 104
#define NOTE_A2  110
#define NOTE_AS2 117
#define NOTE_B2  123
#define NOTE_C3  131
#define NOTE_CS3 139
#define NOTE_D3  147
#define NOTE_DS3 156
#define NOTE_E3  165
#define NOTE_F3  175
#define NOTE_FS3 185
#define NOTE_G3  196
#define NOTE_GS3 208
#define NOTE_A3  220
#define NOTE_AS3 233
#define NOTE_B3  247
#define NOTE_C4  262
#define NOTE_CS4 277
#define NOTE_D4  294
#define NOTE_DS4 311
#define NOTE_E4  330
#define NOTE_F4  349
#define NOTE_FS4 370
#define NOTE_G4  392
#define NOTE_GS4 415
#define NOTE_A4  440
#define NOTE_AS4 466
#define NOTE_B4  494
#define NOTE_C5  523
#define NOTE_CS5 554
#define NOTE_D5  587
#define NOTE_DS5 622
#define NOTE_E5  659
#define NOTE_F5  698
#define NOTE_FS5 740
#define NOTE_G5  784
#define NOTE_GS5 831
#define NOTE_A5  880
#define NOTE_AS5 932
#define NOTE_B5  988
#define NOTE_C6  1047
#define NOTE_CS6 1109
#define NOTE_D6  1175
#define NOTE_DS6 1245
#define NOTE_E6  1319
#define NOTE_F6  1397
#define NOTE_FS6 1480
#define NOTE_G6  1568
#define NOTE_GS6 1661
#define NOTE_A6  1760
#define NOTE_AS6 1865
#define NOTE_B6  1976
#define NOTE_C7  2093
#define NOTE_CS7 2217
#define NOTE_D7  2349
#define NOTE_DS7 2489
#define NOTE_E7  2637
#define NOTE_F7  2794
#define NOTE_FS7 2960
#define NOTE_G7  3136
#define NOTE_GS7 3322
#define NOTE_A7  3520
#define NOTE_AS7 3729
#define NOTE_B7  3951
#define NOTE_C8  4186
#define NOTE_CS8 4435
#define NOTE_D8  4699
#define NOTE_DS8 4978
// The notes of the melody in order both for the music and then the lights
int melody[] = {
  NOTE_E4, NOTE_B3,NOTE_C4, NOTE_D4, NOTE_D4, NOTE_C4, NOTE_A3, NOTE_A3,
  NOTE_C4, NOTE_E4,NOTE_D4, NOTE_C4, NOTE_B3, NOTE_C4, NOTE_D4, NOTE_E4,
  NOTE_C4, NOTE_A3,NOTE_A3,0,NOTE_D4,NOTE_F4, NOTE_A4, NOTE_G4, NOTE_F4,
  NOTE_E4, NOTE_C4,NOTE_E4, NOTE_D4, NOTE_C4, NOTE_B3, NOTE_C4, NOTE_D4,
  NOTE_E4, NOTE_C4,NOTE_A3, NOTE_A3,0,
  NOTE_E3, NOTE_C3,NOTE_D3, NOTE_B2, NOTE_C3, NOTE_A2, NOTE_GS2, NOTE_B2,0,
  NOTE_E3, NOTE_C3,NOTE_D3, NOTE_B2, NOTE_C3, NOTE_E3, NOTE_A3, NOTE_GS3};
int melodyLed[] = {
9, 12, 11, 10, 10, 11, 13, 13, 11, 9, 10, 11, 12, 11, 10, 9, 11, 13, 13, 0, 10, 8, 13, 7, 8,
9, 11, 9, 10, 11, 12, 11, 10, 9, 11, 13, 13, 0, 9, 11, 10, 12, 11, 9, 13, 7, 12, 0, 9, 11, 10,
12, 11, 9, 13,7 };
//  The note duration in the melody for exampel 2 is the shortest and 8 is the longest:
int noteDurations[] = {
  4, 8, 8, 4,8,8,4,8,8,4,8,8,4,8,4,4,4,4,4,8,
  4, 8, 4, 8,8,4,8,4,8,8,4,8,4,4,4,4,4,8,
  2, 2, 2, 2,2, 2, 2, 8, 8,2,2,2,2,4,4,2,2};
const int buttonPin = 2; // the number of the pushbutton pin
int buttonState = 0; // variable for reading the pushbutton status
int led1 = 13;
  int led2 = 12;
  int led3 = 11;
  int led4 = 10;
  int led5 = 9;
  int led6 = 8;
  int led7 = 7;
  int led8 = 6;
void setup() {
  pinMode(buttonPin, INPUT);
  pinMode(led1, OUTPUT);
  pinMode(led2, OUTPUT);
  pinMode(led3, OUTPUT);
  pinMode(led4, OUTPUT);
  pinMode(led5, OUTPUT);
  pinMode(led6, OUTPUT);
  pinMode(led7, OUTPUT);
  pinMode(led8, OUTPUT);
  // iterate over the notes of the melody:
void loop() {
  // read the state of the pushbutton value:
  buttonState = digitalRead(buttonPin);
    // check if the pushbutton is pressed.
// if it is, the buttonState is HIGH:
  if (buttonState == HIGH) {
// sound tone
  for (int thisNote = 0; thisNote < 55; thisNote++) {
    // to calculate the note duration, take one second
    // divided by the note type.
    //e.g. quarter note = 1000 / 4, eighth note = 1000/8, etc.
    int noteDuration = 1100/noteDurations[thisNote];
    digitalWrite(melodyLed[thisNote], HIGH);
    tone(3, melody[thisNote],noteDuration);
    // to distinguish the notes, set a minimum time between them.
    // the note's duration + 30% seems to work well:
    int pauseBetweenNotes = noteDuration * 1.30;
    digitalWrite(melodyLed[thisNote], LOW);
    delay(pauseBetweenNotes);
    // stop the tone playing:
    noTone(8);
else {
//turn off sound
noTone(8);
Step 3: The Tone Function
Playing music in the arduino introduces a function known as tone(). This function controls your ability to play music. In the code it will look something like this:
tone(pin, frequency, duration)
or
tone(pin, frequency)
Where pin is the pin the speaker is hooked up to, frequency is the tone in hertz and duration is how long, in milliseconds.
If you use the 2nd convention, to stop the sound you must have a noTone() function.
noTone(pin)
In the previous step for the melody, you had to include the pitches.h file. This file just gives you a variable for every tuned note in hertz so you don't have to work out basic notes. This makes writing songs much easier!
Step 4: Final Melody
http://www.youtube.com/watch?v=gK09xylL8Ek
    • Pocket-Sized Contest
    • Spotless Contest
      Spotless Contest
    • Trash to Treasure
      Trash to Treasure
