Connect your Xbox 360 online using your laptop (Simplified for Vista ONLY)
 by PuddleOfMudd25
Step 3: Setup the Xbox
Now its time to hook up the Xbox. When you have your Xbox in the desired place, get the Ethernet cable and plug it in. Then, connect it to your laptop. Now, simply go to the settings tab on the Xbox, and select Network Settings. Run the test, and it should be successful.
So what did bridging the connections do?
By creating a bridge, you connected the wireless and LAN connections together. The LAN provides a network to any computer connected to it (In this case, the Xbox), and the bridge will connect the Internet connection, and the Local Area Connection together providing internet. Easy, huh? Easy enough to not understand.
ashrestha7 says: Jul 8, 2011. 3:38 PM
Very easy!! Thanks!
sbloomfield1 says: Jul 6, 2011. 2:20 AM
it does really work its a chalenge but if you have windows vista than go to youtue and search it up i dident even have to bridge the conections and it still works use this link it helped me http://www.youtube.com/watch?v=uAw6xVN9vsg
jhenry8 says: Jun 23, 2011. 1:41 PM
best i tryd it and it was working without cable amazing
1cocodog says: Nov 16, 2010. 7:40 PM
It took some time since my computer is a bit different but when i got to bridging the connections i highlighted both and right clicked it, but all the my options are grey and doesnt have bridge onnection option there. What do i do?
Skiggs says: Nov 9, 2010. 8:14 PM
I got everything working and connected to Xbox Live. But when I go play an online match on COD: Black Ops after a few minutes it will say connection interrupted or something close to that. It never disconnected during the updating process(which took a while) Have you had this problem before and/or know how to fix it?
Thanks
louieaw says: Dec 28, 2009. 7:41 PM
 Well, I know there are many questions and problems that people have been having, but please excuse me if this had already been asked...
When I bridge the connection, I can't connect to the internet. I am connected to my wireless network, but no internet. Any advice appreciated.
Little Einstein in reply to louieawSep 27, 2010. 5:31 PM
Firstly, we need to now wether it's just your Xbox 360 that can't connect to the internet or your laptop can't as well.
On my router, if I am connected to the network but not the internet, it means that my telephone cable (if you use ADSL) is unplugged, or that my internet temporarily went offline. That basically means the internet is down, or your router is not configured correctly. Make sure your cables aren't loose. Then just wait a few seconds. If you still can't connect, then there's something wrong with your router/internet.
Hope that helps (i'm not sure if it will, because we all have different routers/ISP's.)
Temperamento says: Feb 12, 2010. 7:51 PM
The only problem I have is when I test my connection, nothing works lol
boblordofmonkeys in reply to TemperamentoApr 6, 2010. 2:00 AM
 me 2
Temperamento in reply to TemperamentoFeb 12, 2010. 7:52 PM
When I test the connection it doesnt connect to any networks.
sohailnaz says: Jan 9, 2010. 2:44 PM
u rock omg i swear it actually works!!!!!!!!!!!!
DanwiseG says: Nov 25, 2009. 1:51 AM
A little more detail for the simple folk.....
If you are on an open network, you shouldn't have to do ANYTHING manually.
Do the steps he said. Make a Bridge.
Go to network settings in your xbox360 and continually test.
(Don't forget you actually have to have a GOLD LIVE account to play online)
(Also tell your xbox to automatically get new IP address.)
If connection fails, click "DIAGNOSE" windows should diagnose this and come up with a solution for you. Most likely it will pop up something about enabling "automatic IP" or whatever. Choose that one.
Windows should crank for a bit. If it STILL says its failing to connect, diagnose again, or click "try finding another solution" whatever. It should now have popped up a box with an option of "RESET (insert your connection name here) NETWORK ADAPTOR"
Click that.
Windows cranks for a bit.
Test the connection on the xbox and that more than likely will fix your problems.
natalie1892 says: Oct 30, 2009. 12:03 PM
I have done all of the above. When I run the test it still fails. My xbox says that it can not obtain an IP address from my router or modem. Any help? Thanks.
yankes77 says: Oct 20, 2009. 5:23 PM
mine says the dns server setting is wrong?
how do i set that up?
zombierob says: Sep 8, 2009. 10:56 PM
this worked with no problems thanks much !
caboose0 says: Aug 23, 2009. 5:29 PM
It started to work and all, then it said "there's a problem with your connection. Select More into for a description of the problem and how you can fix it" I Hit more info and nothing worked...can anyone help me?
reansalu says: Jun 17, 2009. 2:08 AM
Yay, after many attempts I've finally cracked it, so don't give up everyone! Here's all the things I've done, in case it helps anyone: Last thing I changed was the cable I used to connect my sons vista premium laptop to the xbox360. I was using the ethernet cable supplied with xbox360 (which was a patch cable), that wouldn't bridge connections; kept saying need 2 LAN connections without internet sharing, blah blah. As a shot in the dark I tried a cheapy spare cable I had, doesn't say whether its a patch or crossover lead, but it had the correct connectors at either end! I turned internet sharing off in properties and ticked the boxes to allow automatic finding of IP addresses on both network connections; bridge connected and went to xbox 360 network settings where it showed it had found the laptop, tested xbox live connection and success at last. I am NO techno head, so can't answer any questions, all I can say is, the cable change appeared to work for me and my son is now happily playing with no problems so far! No idea if it makes a difference, but someone mentioned to try turning off firewall/anti virus etc, my sons laptop only has AVAST antivirus and windows antivirus enabled.
SjMac26 says: Jun 13, 2009. 1:38 AM
Mine failed to work for some reason, I think it's the DNS settings, how do I get them as they're 0.0.0.0 on both
urtragest says: May 25, 2009. 10:51 AM
exellent easy and effective thnks
biggieb517 says: Apr 30, 2009. 6:21 PM
the most simple guide ive ever used thanks alot very easy and fast
uaobulldogs says: Apr 6, 2009. 10:46 AM
I loved your guide, simple and easy...but there was one problem with my xbox it connects to my network but then fails the network to internet test, i was wondering if you know the cause of the problem and could maybe help me out.
FrostRime says: Mar 24, 2009. 11:36 AM
kept getting an ICMP problem when connection attempted to contact Xbox Live. It worked itself out in the minute it took me to think of how to phrase my problem on google.com This was an awesome guide, thanks.
Jmax09 says: Feb 16, 2009. 8:00 AM
This is great! I've tried it but I am stopped at the test for the Media Connection. I'm using a laptop with Wi-Fi. It fails at the IP address. I can see your talking about Xbox.com and flash drives but I don't know where to find it or what to do. Help? :D
PuddleOfMudd25 (author) in reply to Jmax09Feb 16, 2009. 3:51 PM
So are you connected to Xbox Live, or is it just the Media Centre?
killcycle in reply to PuddleOfMudd25Mar 16, 2009. 10:39 AM
Ok i finally bridged it but the 360 ain't picking it up. Do i have to some how enable my 360 or something? Or set the bridge so it bridges to the 360. I just don't know hat i missed.
Jmax09 in reply to PuddleOfMudd25Feb 17, 2009. 1:18 AM
Nither. I'm going to buy a sub for Live, but not until I connect.
TwiztofFate says: Feb 28, 2009. 1:16 AM
Hmmmm, i did it all successfully but when i test my connection it has: xbox360..........network..........internet.........xbox live connected connected connected failed it says there is a problem with my connection. Why? my signal strength is excellent.
mccuj6 says: Feb 25, 2009. 5:34 PM
So, having problems. Trying to hook up my labtop to my xbox 360. Im using a wifi signal from someone to access the internet to my labtop. the furtherest i have gotten is to mtu and it fails. im using windwos vista and i have a good signal. Need help
Mac_Man94 says: Feb 15, 2009. 5:18 PM
DUDE I did all that and the network connected but then it says "PC not listed" What's going on???
PuddleOfMudd25 (author) in reply to Mac_Man94Feb 16, 2009. 3:52 PM
Where did it say that?
Mac_Man94 in reply to PuddleOfMudd25Feb 16, 2009. 6:03 PM
I was connecting to the network and got on that but when it went to the comp connect part it didn't work and thats when the message came up.
xtortionist says: Feb 8, 2009. 12:37 PM
OMFG thank you SO much it worked! All I had to do was get a cat5e ethernet cable from radioshack for $15!
PuddleOfMudd25 (author) in reply to xtortionistFeb 8, 2009. 5:35 PM
Wow, thanks! That's a difference than the usual "it wont work, help plz"
xvickyx182x says: Feb 6, 2009. 10:37 AM
can't do it. what a waste that was for me.
Kryptoknight says: Jan 19, 2009. 9:09 PM
I set my 360 up like this to my desktop computer but when playing GTA4 I keep losing connection, has anyone else experienced this, or have any idea why this would be?
PuddleOfMudd25 (author) in reply to KryptoknightJan 20, 2009. 1:14 PM
Yes, all the time. I don't know exactly why, but I just honestly ignored it. It stopped after a while, but man was it annoying! I feel your pain.
iuhawkis says: Dec 26, 2008. 9:45 PM
Ok...I followed the instructions that were given and I have a bridge configured but I am still getting the failed ip message. I don't understand what I am suppose to be looking for on xbox.com. Any help would be awesome.
iuhawkis in reply to iuhawkisDec 26, 2008. 10:44 PM
Finally...I fixed it...I found the drivers and installed them, switched back to automatic and it works...only took countless hours..:) but at least it works now
GKTony1 says: Nov 23, 2008. 8:09 PM
Ok I am stupid to all this. I get a failed IP address. how do I get what info from xbox.com? Is mine going to be different because I use a sierra wireless aircard 595U by Sprint that plugs into the USB port? Does this change anything? Help me Please!
tintintintino says: Jun 21, 2008. 5:41 PM
ok so my xbox 360 hates me. its def not letting me connect. it fails at ip address. help!
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
