Connected Arm Lift, a Knex Ball Machine Lift
4,778
21
86
Posted in PlayKnex
Introduction: Connected Arm Lift, a Knex Ball Machine Lift
About: Hey! I'm Sandroknexmaster. I like building with knex, especially ball machines. I live in Belgium. I speak Dutch, but also English and French. I hope you like my stuff, and like always comment, rate &amp...
Hey everyone!
I present to you the second new lift from my ball machine Euphoria. The first one is here.
The Connected Arm Lift is in my opinion a cool looking lift, with a pretty low piece count.
It works very good, I've never seen a ball fall of the lift.
If you build this lift, read every image note!
I hope you like it and have much fun with building!
~Sandroknexmaster~
video:
Step 1: Piece List
First you have to count the pieces.
They're all named by their original color.
RODS:
green: 81
white: 37
blue: 50
yellow: 48
red: 88
grey: 46
Total rods: 350
CONNECTORS
dark-grey: 15
light-grey: 2
orange: 48
red: 10
green: 26
yellow: 39
white: 11
purple: 89
blue: 23
Total connectors: 263
OTHER PARTS
tan clip: 3
Y-clip: 6
blue spacer: 27
silver spacer: 76
small blue gear: 1
medium yellow gear: 1
medium hub: 1
medium tire: 1
green motor: 1
Total other parts: 117
GRAND TOTAL: 730
Step 2: Entrance
We will start building the entrance. Here the balls can enter the first arm.
Step 3: Motor Section
Here we will build the motor section. It contains the motor, the gears and the axle.
Always slide the switch of the motor to the left.
Step 4: Frame
This is the most boring part from the lift... But it's also very necessary so just build it!
Step 5: Exit
The exit. Here leave the balls the last arm.
Step 6: Arms
Now we will build the four arms. They pass the ball to eachother so it can get from the entrance to the exit.
Step 7: Arm Connections
This is the last part from the lift. They connect the arms and the cranks.
Step 8: Finished!
Yay! The Connected Arm Lift is complete!
Thanks for building my lift or watching the ible only.
When you've built the lift send me a photo, then I can add it to this step!
I hope you liked it!
See you!
~Sandroknexmaster~
  • Microcontroller Contest
  • Spotless Contest
    Spotless Contest
  • Woodworking Contest
    Woodworking Contest
86 Comments
We just built this lift. It works great for a couple of rotations, then there seems to be a problem with the gears meshing. It starts skipping and binding. Any ideas?
Did you use the same motor as in the instructions? If not, yours might be not strong enough.
Yes, the green one.
That's weird, then I suggest you try to place the gears in a different position. Maybe then it will work.
here is mine you can see a instructable with it at
https://www.instructables.com/id/Blizard-10-a-Knex-ball-machine-in-progress/
Hm that's very weird, I've never had trouble with this lift, it always worked great. You can send pics, questions, or any other things I can help you with in PM. I'll do my best to help you out.
btw, 2600th comment :D
hey ik heb deze lift gebouwd maar heb wat problemn... bij het begin bij die rode stang dan valt me bal er soms over heen als ie aan komt maar ook als die ball vanger ofzo komt dan pakt ie de bal niet. dus kun je me helpe?
Stuur me wat foto's in een bericht, dan kan ik je mss verder helpen.
sorry man kan geen fotos maken maar het is zo dat het rode staafje aan het begin soms te laag zit
En heb je als tegengewicht hetzelfde wiel en dezelfde band gebruikt als in de instructies?
