You will need:
- EL wire
- inverter (chose one for the length of the wire you are going to connect)
- wire stripper
- cutter or scissors
- solder iron with fine tip
- shrink tube
- hair drier
- uninsulated ferrules
Remove these ads by
Signing UpStep 1Prepare EL wire
At this point you will be able to see the inner conductor covered by the phosphorus layer and the outer conductors, the two fine wires.
Using the cutter blade scratch the phosphorus paint out of the inner copper conductor for approximately 4 mm (0.16"). Be careful to remove it completely or welding will result difficult. Be careful not to cut the two fine wires. The EL wire must look approximately like the one in the last picture.
Great instructable!
I would think soldering the ferrule might cause damage to the outer casing to the el wire - obviously it doesnt. If it becomes problematic, a person could pre-tin a dot of solder on the ferrule so that adding the connection wire would only take a very brief second and ensure no cold solder joints :)
Great stuff!
