Introduction: Connecting Particle Photon to Cayenne
Picture of Connecting Particle Photon to Cayenne
Trying to keep all my boards connnected to Cayenne, which are compatible with Blynk, I want to experiment with my Photon.
In a post of this community I read about an unofficial library, but had not detailed steps, so I decided to write this tutorial step by step, with images and code included so that you can connect a Photon to Cayenne. The truth is that this library is still not very worked as Arduino library, but taking certain considerations you can achieve connect smoothly
Step 1: Add New Device (Select Arduino)
Picture of Add New Device (Select Arduino)
Step 2: In Particle Coud Editor, Search for Cayenne Library
Picture of In Particle Coud Editor, Search for Cayenne Library
Step 3: Use the Example, Modify Auth Code, Build and Flash the Code.
Picture of Use the Example, Modify Auth Code, Build and Flash the Code.
Step 4: Rename the Device
Picture of Rename the Device
Step 5: Add New Widget (User Virtual Pin) for Control a Led
Picture of Add New Widget (User Virtual Pin) for Control a Led
Step 6: Update the New Sketch
Picture of Update the New Sketch
Step 7: Try Controlling the Led
Picture of Try Controlling the Led
About This Instructable
469views
4favorites
License:
More by laurencehr:LinkIt ONE GPS Live Tracker With CayenneRemote Doorbell With Custom (mp3) Song With CayenneConnecting LinkIt Smart 7688 Duo to Cayenne
Add instructable to:
