Step 5Choosing your diode
U_L = - L * delta i/delta t
So theoretically if delta t equals zero U will be infinite.
But due to the minus in front you can add a diode in the "false direction" parallel to the relay. So the current can flow till its zero so the voltage is also zero.
I've got a couple of questions for you though.
First the easy one. Could you explain the formula in step 5. What is "U_L", "L", "delta i" and "delta t"? Where do I find their values in regards to the components I'm going to use. Just not sure if it matters what rating diode I use, or if it's merely mathematical proof that I will need a diode and any diode will do.
Lastly, I'm going to be applying this for a project of my own, but want to make sure I can get the relay circuit working before I get an Arduino. Can I simulate the arduino by applying a 5v positive to where the arduino would go, with the negative to ground in the circuit?
Again, many thanks for this guide, and thanks for any help you can give me.
Regards,
The Cageybee
Appologises! :-)
The Cageybee
