Note that I never signed anything in my lease forbidding me to have a washing machine--you might want to check your own lease for details. Also, my downstairs neighbors are cool with their dishes rattling when I do laundry.
Remove these ads by
Signing UpStep 1Extension Hoses
I extended the drain hose with 1-1/4" ID braided tubing--it is a friction fit around the outside of the drain hose (see the second photo). I secured it with a hose clamp. This works fine with a corrugated drain hose; I'm not sure how well it would work with a smooth surfaced hose.
PROBLEM:
I can't get the washer to fill. I'm not sure what is up. Do I need a hose hooked up to my hot water inlet? The washer has an extension cord for power hooked up. where is doesn't have a plug in. No way around that. Please help me!! Thanks
Be sure to use a snare catcher for the water going out or you will start clogging up your plumbing. An amazing amount of lint collects and that gets really expensive.
They clamp on the water outlet hose with a hose clamp AND you should also use a hair snare for the sink as a back up. Hardware stores & home improvement stores have both. You can also buy a battery operated water alarm. Ones that just set off an audible alarm - and ones that dial a phone number in case of a leak.
Basically, I attached a diverter (meant to add a handheld shower sprayer to a regular shower) to the shower nozzle. This way, I didn't have to remove & add the showerhead-- just turn a lever. Then I added an adapter from the diverter's 1/2 inch pipe thread to the washing machine hose's 3/4 inch thread. The washing machine fill hose attaches to the adapter-diverter combination.
On my machine, the drain hose has to be in an upright position or the washing machine won't fill, so I attached it with a suction cup to the back of the shower. Definitely use a drain screen-- the lint builds up quicky.
I'd definitely recommend being nearby when you're running this setup--I usually wandered back into the room when it was draining to check on it, and I never left it to run a load unattended.
It is not legal to drain a washer into a sink less than 12" deep.
The main part of this article is for the water supply. you can do anything you ant to supply a washer with water including a bucket. The main problems with any laundry hook-up are 220 for a dryer and the proper venting and capacity for drainage of the washer (17 gpm requiring either a a 2" pipe (certainly not the case int hat sink) or 20 gallon capacity sink above 1.5" diameter pipe)
Click4Carbon
http://www.acehardware.com/product/index.jsp?productId=1366712&cp=&pg=2&sr=1&origkw=faucet+adapter&kw=faucet+adapter&parentPage=search&searchId=19590697433
http://splendide.com/154187104A_install.pdf
