3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Connecting a Washing Machine to a Kitchen Sink
I'm an apartment-dweller, and I managed to inherit a washing machine and dryer (no more collecting quarters and trips to the laundromat--yay!). But there are no hookups in my apartment (boo!). This is my solution to this problem.
Note that I never signed anything in my lease forbidding me to have a washing machine--you might want to check your own lease for details. Also, my downstairs neighbors are cool with their dishes rattling when I do laundry.
Step 1Extension Hoses
Extension Hoses
None of the hoses that came with the washer are long enough to reach the sink. The supply hose is female hose fitting (both ends)--I just cobbled one together out of plastic hose repair fittings and clear braided tubing (all available from Home Depot).
I extended the drain hose with 1-1/4" ID braided tubing--it is a friction fit around the outside of the drain hose (see the second photo). I secured it with a hose clamp. This works fine with a corrugated drain hose; I'm not sure how well it would work with a smooth surfaced hose.
44 comments
1-40 of 44next »
Dec 9, 2010. 10:17 AMfirestorm521 says:
I live in an apartment and I inherited a pair of front load w/d for an early wedding gift. I am trying to set up the washer. I have a garden hose running from my shower head(only place i could get my adapter to screw onto) and that goes to my cold water inlet on the washer. I'm using corrugated pipe for my drain and going to my bath tub. Both hoses are 25 feet. Not sure if that matters?
PROBLEM:
I can't get the washer to fill. I'm not sure what is up. Do I need a hose hooked up to my hot water inlet? The washer has an extension cord for power hooked up. where is doesn't have a plug in. No way around that. Please help me!! Thanks
Oct 5, 2011. 10:26 AMmatchbookhymnal says:
Some washers won't fill if the drain hose isn't higher than the washer (mine is one). I had to secure the drain hose about waist-high to get it to work.
Aug 22, 2011. 12:05 AMSunnyGuy says:
If anyone knows how people in New York hook up a washing machine to their bathtub. Please leave the information here. Thank You.
Be sure to use a snare catcher for the water going out or you will start clogging up your plumbing. An amazing amount of lint collects and that gets really expensive.
They clamp on the water outlet hose with a hose clamp AND you should also use a hair snare for the sink as a back up. Hardware stores & home improvement stores have both. You can also buy a battery operated water alarm. Ones that just set off an audible alarm - and ones that dial a phone number in case of a leak.
Oct 5, 2011. 10:25 AMmatchbookhymnal says:
I hooked a Haier portable washing machine to my shower. I did not use braided tubing and clamps-- just bought an extra washing machine hose and a coupler to extend what the machine came with. You can also use garden hose, since it's the same size as washing machine hose.
Basically, I attached a diverter (meant to add a handheld shower sprayer to a regular shower) to the shower nozzle. This way, I didn't have to remove & add the showerhead-- just turn a lever. Then I added an adapter from the diverter's 1/2 inch pipe thread to the washing machine hose's 3/4 inch thread. The washing machine fill hose attaches to the adapter-diverter combination.
On my machine, the drain hose has to be in an upright position or the washing machine won't fill, so I attached it with a suction cup to the back of the shower. Definitely use a drain screen-- the lint builds up quicky.
Sep 20, 2011. 5:29 PMwrichter says:
Have you had any issues with the washing machine draining too fast for the kitchen sink to keep up?
Nov 3, 2007. 7:14 AMintrinsic2005 says:
You can find a "quick release" adapter too. It allows you to clip onto the kitchen sink faucet and unclip with a single motion. The one I have still has an aerator on it when I unclip, but I got it overseas. The ones I have seen here ( at ACE Hardware in the plumbing section ) don't have an aerator on the adapter parts, so if you want to have the aerator when you aren't using the washing machine, you'd have to unscrew the adapter and put the aerator back on. If you're not attached to your aerator, you can put the ACE adapter on and leave it. Then you simply clip the quick release on and off as you need to use the washing machine.
Feb 9, 2010. 6:05 AMliltonyia says:
 do i hold button red button in while putting it faucet
Oct 20, 2009. 6:42 PMPCfreak says:
kinda like those quick release adapters you find On Portable Dishwashers
Jan 18, 2010. 1:34 PMbikerchick4God says:
attach one woman's pantyhose knee hi to the outlet to prevent junk from the drain water clogging the drain over time.  Anyone else have a big problem with sand accumulating in the screen of your washer;s water inlet?  It's often I had to clean that inlet in coastal FL.
Jan 16, 2010. 12:20 PMbikerchick4God says:
Me too!!  This is exciting.  I didn't want to sell my W/D as I downsized from a house with garage to a smaller dwelling without hookups.  My friend bought this and that to extend the hoses but I haven't used his 'system'.  I will implement your method and feel confident I can have clean clothes by tomorrow.    Just last night I saw 4 police cars at a laundramat.  I don't wanna go to a laundramat.  Thanks to you I don't have to!
Nov 19, 2009. 11:45 AMrandom4_6 says:
Just to be clear, this kind f set up voids your homeowners or rneters insurance and doing this would expose one to liability for any damages from the electrical connection, and fro water damage.
It is not legal to drain a washer into a sink less than 12" deep.
The main part of this article is for the water supply. you can do anything you ant to supply a washer with water including a bucket. The main problems with any laundry hook-up are 220 for  a dryer and the proper venting and capacity for drainage of the washer (17 gpm requiring either a a 2" pipe (certainly not the case int hat sink) or 20 gallon capacity sink above 1.5" diameter pipe)
Oct 22, 2009. 2:55 PMobfuscode says:
Plastic soda bottle caps work perfectly - when we moved we had to cap the hose connections and didn't have special caps - the soda bottle caps fit and screwed on tight without leaking - your mileage may vary but give it a shot before buying special ones.
Sep 5, 2006. 5:29 PMtyeo098 says:
Ok, 1. if you8 live in an apartment... why did you get a washer and dryer? 2. how did you hook up the dryer w/o a 220v connection? 3. nice job!
Oct 20, 2009. 6:45 PMPCfreak says:
let me guess you used the same type of cord thats on the elec stove?
Aug 19, 2009. 2:28 PMopir says:
any chance you can tell me the hose size and hose mender sizes? this little project might be saving me 1300$ of plumbing work :) great idea
May 14, 2009. 1:12 PMjcwang0706 says:
Awesome tutorial. When you want to do a wash, do you just keep the faucet on the whole time? Or do you have to manually turn it on and off throughout the wash cycle? Thanks!
Jul 19, 2009. 4:05 AMantmodeli says:
while the machine is full and the clothes are washing, where is the water suppose to go if you leave the faucet on?
Dec 14, 2008. 2:02 PMMadinat says:
this is aweseome! do you over have to worry about overflow?
Sep 5, 2006. 8:34 AMleevonk says:
Just to clarify for people (though it might be obvious). You turn the water on before you even start the machine, the washing machine has solenoid valves that will allow the water in at the appropriate times.
Sep 5, 2006. 11:23 AM0.775volts says:
If you wanted to get a little more fancy, you could just tee off of the sink connections in the cabinet beneath the sink. This would give you control over hot and cold water. You could tee and add a ball valve if you wanted to, and could thus disconnect the hoses whenever you felt the need. Nice job!
Dec 14, 2008. 2:06 PMMadinat says:
this is what i'm thinking of doing. i have some connectors from the bathtub that i have access to. some other apts. in the community i live in have put in w/d at this location, all i have to figure out is how they managed to drain the tub.....
Nov 17, 2008. 12:14 AMClick4Carbon says:
To learn more about Energy Efficient Washing Machines as well as how to offset your Carbon Footprint visit Click4Carbon.
Click4Carbon
Nov 16, 2008. 10:53 AManthro says:
You are truly a Godsend!!! I just moved into an apartment less than 2 months ago and trying to always scrounge up quarters has been the biggest hassle ever. I have been looking on craigslist for apartment washers and now feel lousy because I have been passing up all of the regular washers. I am so happy to have found this information! Thank You so much - you have no idea!
Aug 25, 2008. 1:34 PMdelta_faucets says:
Great info here, keep up the good information!!
May 15, 2008. 1:59 PMrobhybrid says:
A lot of faucets don't have usable threads. In those cases, you can just slide the hose over the faucet and just hose clamp it on.
Nov 27, 2007. 9:06 AMtubularist says:
this is perfect, exactly what i want to do. but, how did you hook up the dryer?? thanks,
Feb 23, 2008. 2:39 PMfreaky421 says:
I've been looking into that, & for a gas dryer you're pretty much using the good old sun's warmth. Just like in the old days. If you happen to find another way, PLEASE let the rest of us know! :)
Jan 27, 2008. 8:15 AMstasterisk says:
Holy Information, Batman! I'm fixing the drain in the bathhouse, and I thought I'd check instructables for tips. And here it is, exactly what I was looking for.
Nov 3, 2007. 7:08 AMintrinsic2005 says:
Good work around. :-) I've been doing something similar, but I had a plumber friend do the connection to the rear of the machine a bit more formally and I used a regular short garden hose, the type that you can roll back into its case by cranking a handle on the side. I got the idea to do this from my experience living in Asia and the Middle East. Most houses there do not have laundry hookups, so SHARP, HAIER, LG and others make the machines they sell there with regular electric plug and with hoses that operate pretty much like you have done. Here in the states, HAIER sells a couple washing machines that work on kitchen sink hookups. I've got a friend who's using one and he seems fine with it, . . other than it not holding too much ( 6 pound max, I think ). He can do basic clothing, sheets, pillow covers, table cloths, but has to take blankets and large things like that to the local laundromat still.
Dec 13, 2006. 10:57 AMhaunted_lady says:
I really love this idea and your use of velcro! I found a really small washer for apartments but it is 200 bucks and room for like nothing. YOUR idea is wayyyy better and I had never known a person could do this. I found you ona google search!!! Pat yourself on the back for an excellent job! I must investigate how you hacked the stove connection! BUt for now a washer is all I need anyway :)
1-40 of 44next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
10
Author:Bats22
Building energy efficiency/construction industry consultant; woodworker; casual (not hard core) cyclist.
