Support DIY and Instructables : Become a Pro Member Today!
Connecting a 12V Relay to Arduino
step 1
step 1Measure the coil resistance
We are going to measure the coil resistance to calculate the current.
First we must find the coil:
On some relays the pins are labeled so you can just measure at pin 2 & 5.
Otherwise you have to measure at every pin:
Between two pins you should have between 100 and 10 000 Ohm. Remember that value. That are the two terminals of the coil. The coil is not polarized so its not important which one goes to V+ or GND.
If you have found those there are only three left. Between two should be a connection (if you measure a few Ohm its okay but everything above 50Ohm is too much). One of them is NC and one is COM. To find out which is which let one probe connected and connect the other to the pin thats left over. If you connect the coil to 12V DC it should make a clicking noise. If your mulimeter now shows a low resistance you have found COM and NO. The one probe you didn't move is COM the other is NO.
Remove these ads by Signing Up.
To View All Steps on one page,
Go Pro Today!
Related
