Conserving Water: 2 Stage Toilet Flush
People these days are turning green. And it not from the gas station deli. So here is a little thing you can do in your home wheather you own or rent that you can do to conserve our precious water. Newer (i.e. more exspensive) toilets now come with a 2 stage flusher. Stage 1, a low volume half flush, is for liquid waste; while the stage 2 flush performs a full tank evacuation to wash away the solid waste. As a green consumer you could go to a home improvement store and buy after market toilet parts, but why spend money to conserve? I'll show you how to create a 2 stage flushing toilet for $0.00.
Step 1Learn your toilet's parts
Learn your toilet\
Become framiliar with your toilet and how it works.
The lever pulls up on the flapper.
The flapper opens letting tank water fill the bowl.
Tank water level lowers and the fill valve float drops letting fresh water into the tank.
Tank water empties the flapper falls back into place.
Water from the fill valve fills tank.
Water pressure holds flapper down and raises the fill valve float
Fill valve float stop water from filling tank.
3 comments
Feb 12, 2009. 9:19 AMchuckr44 says:
At my house you would need a 3 stage flush: - light load - heavy load, and - Oh my gawd! Did that come out of you?? Is that corn??
Jun 17, 2008. 11:33 PMsideways says:
My junky old toilet already needs two flushes to empty, LOL. But it's a great idea. No need to waste a full flush if it isn't needed. One could also leave liquids to sit, flushing only once every few uses. "If its yellow, let it mellow; if it's brown flush it down".
Oct 25, 2008. 1:03 PMPureBreed says:
uhh, pee smells too u know (which is bad for me cuz me bathrooms 3 feet from my bed) xD
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
14
Author:Auger Duval
