3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Construct a Japanese Torii Gate for Your Garden
For some time, I had been thinking about building a Japanese torii gate for my garden. A torii gate marks the approach and entrance to a Shinto shrine. It is the division between the physical and spiritual worlds. Shinto is a native religion of Japan and was once its state religion. Probably the most famous torii is the one at Itsukushima Shrine located at Miyajima, near Hiroshima. Mine is a little more modest.
Step 1Torii Components
Torii Components
After a bit of poking around on Google, I found that all torii gates are made up of three horizontal components:
- Kasagi: The very top beam of a torii gate. These beams can be straight or curved.
- Shimagi: A second beam directly underneath the kasagi in more complex forms of torii gates. Their ends are either straight or cut with an inward slant and the overall shape of the beam is that of an upside down trapezoid.
- Nuki: The secondary beam of a torii gate. On more complex torii gates, it is held in place by kusabi (wedges). This beam is always straight.
The other components of a torii are the:
- Hashira: The supporting pillars of the torii gate
- Gakuzuka: A centre post that connects the Nuki & Shimagi (optional)
- Kusabi: A wedge used to hold the Nuki in place (optional)
The Shimagi is usually placed below the lintels at a distance about equal to the diameter of the pillars.
The dimensions that I ended up choosing for my torii are somewhat of a trade-off given the thickness of my Hashiras (poles).
53 comments
1-40 of 53next »
Apr 9, 2012. 2:48 PMsimpatico says:
I'm interested in building a downsized Torii gate of timber bamboo. Any thoughts on the durability of the bamboo in the ground, using concrete "feet" or not, gravel?
Apr 16, 2010. 12:44 PMarkie says:
Nice work. Well balanced design. You mentioned (Feb '07) that the concrete had cracked. Would it be possible, considering your climate, to use the material that you excavated for the hole as back-fill? Coupla' shovels at a time and tamp down with an iron bar or wooden post?
An old hillbilly watched me trying to erect posts for a barn. When I started mixing concrete, he asked if the wet slop was going to contact wood. I said yes. He asked if I thought the wood would absorb any moisture and swell. I said yes, I guess so. He asked if the wood and concrete would eventually dry. I said yes.
Then he asked, "When the wood dries, and shrinks, won't that leave a gap between the dry wood and the cured concrete? Won't any rain trickle into that gap and soak your post all the way to the bottom? Don't ya' think that wet wood will encourage mold and bugs and rot?"
He went away. I stopped using concrete.
May 14, 2010. 8:17 AMejsilver26 says:
Awesome explanation. I've always been told to ensure that wood doesn't touch concrete, but that is best reason WHY that I have heard. I've been told that they will rot, but not why they will rot. It makes perfect sense.
I'm assuming that treated wood might not be as big of an issue, since it can be treated to resist absorbing wood and rotting. Any thoughts?
EJS
May 14, 2010. 2:41 PMarkie says:
I don't want to 'highjack' the thread of BlueRock's excellent Japanese torii, so this will be (moderately) brief.
Totally submerged wood, treated or not, can stay in prime condition for centuries. New Zealand's kauri wood is workable after 45,000 years buried in the wet, boggy ground. Logs from the Louisiana swamps and the American Great Lakes are being recovered and used after centuries underwater. They stayed wet.
Log buildings in Europe have been gathered in outdoor museums and are open to the public. With 4-foot eaves to protect the wood from rain and snow, and stone sills to keep them from ground contact, the buildings are in good shape after 500-600 years. They stayed dry.
The interface between dry and wet is where the damage occurs. I removed a fence for a friend in the Arkansas Ozarks. The posts were made of aromatic Western red cedar... the same long-lasting wood used in cedar chests. The above ground portions of the posts were weathered but strong and intact. As I dug, and wiggled the posts, they snapped off at the rotted areas at ground level; however, digging for the buried portions revealed solid timbers. No evident aging or damage to the underground wood.
The treated lumber available at the limber yard or 'big-box' hardware store normally has a rating (in years) and a notice that it is intended for non-ground contact. Ground-contact rated wood is available, but the price goes up. There is a marine-grade treated lumber which is VERY expensive, but survives the wet-dry cycle for years.
I hope this helps... and my apologies to BlueRock for my wordy reply.
Apr 11, 2010. 9:06 AMRoger408 says:
It may depend on your climate, but here in northern California, we need to put 6 inches of gravel in the bottom of a post hole, then add the concrete around the poles to anchor them.  That allows the moisture that gets into the wood to drain away and posts last much longer.  Redwood fence posts done that way last up to 50 years, fully encased in concrete you're lucky to get 10 years before the part in the ground rots away.
BTW what is the species you call oregon?  Could it be douglas fir? Around here Oregon is  a piece of geography, that little bit of a state just north of us ;-).
May 28, 2011. 6:44 AMpaxdonnaverde says:
Thanks for that excellent tip Roger, I didn't understand the science behind the post-to-gravel method though I've seen it done that way.
Apr 12, 2010. 8:36 PMCulturedropout says:
Looks great!  Would it be total sacrilege to use PVC pipes for the uprights?  No more problems with rotten wood.
Apr 11, 2010. 9:25 AMTHYMETOCHAT says:
Beautifully done!   What an entrance into your garden!  What is the color you used called?  It's PERFECT!  Thanks for sharing.  Great instructable.
Jun 19, 2011. 7:42 AMtinker234 says:
wow love it
May 22, 2011. 3:59 PMCarlos Marmo says:
Wonderful!
Be Blessed this Torii!
May 10, 2010. 1:55 AMfunwithdiode says:
 an interesting bit of trivia: it is believed that if you throw a coin and it lands on the top of a torii gate you get instant acceptance into heaven, However! if you miss the top or it falls of you go to hell, there are no second chances and make note that if you knock off somebody else's coin they get sent to hell.
Apr 11, 2010. 11:43 AMREA says:
for those curious, this is a myouji torii style.  for more styles click here.
Sep 18, 2009. 3:33 PMJahleim says:
Is it possible to download this.... It is by far the best and most informative instructions,And Iam doubting I will find anything remotely as informative and so easy to follow. Thanks to the uploader.
Sep 18, 2009. 5:41 PMJahleim says:
Thanks BlueRock. Got the download but had to save target and coy the instructions page by page,painstaking but worth it Thanks.
Sep 11, 2009. 11:57 AMDvickery says:
I am unfamiliar with the terms Copper Logs and Oregon wood. I assume copper logs may refer to what we call pressure treated (cupric arsenide). Oregon wood I have no idea of.
Aug 12, 2009. 7:45 PMD.L.H. says:
This is well written and instructed good job on it.
Aug 14, 2008. 4:16 AMWayne_san says:
I completely understand the limitations of budget affecting choice of materials. For more classically Japanese proportions of a Torii gate, I recommend: The hashira be made to "lean in" slightly, approximately their own width. A plumb line dropped from the center of the nuki at the OUTside edge of the hashira should just touch the INside edge of the hashira at the ground. The hashira size (diameter) be 1/10 the measure of the opening. The distance between the inside edges of the hashira at the ground be equal to the height from the ground to the bottom of the nuki. The length of the nuki on each side, from the center of the hashira to the end of the nuki, be equal to 1/3 the length of the center portion of the nuki (between the hashira), from center to center on the hashira. The nuki height be equal to the hashira -- and the width should be 2/3 its height -- for example, 150 mm x 100 mm. With those proportions of the hashira and nuki, it will be necessary to make the nuki in 3 sections, 3/5 for the center section, and 1/5 for each of the end sections, plus enough additional length to cut tenons to fit into the mortise in each hashira. Side-by-side or over-and-under tenons will work equally well. The kusabi are absolutely indispensible for this type installation. I also recommend tenons at the top of the hashira, and corresponding mortise in the shimagi. I advocate building a torii gate without metal hardware. So, consider boring through the tenons once assembled and driving a wooden pin through the entire joint. Remember that the hashira will not be exactly perpendicular to the ground, if erected "leaning in" as I've described, so the mortise will need to be adjusted slightly so that it is still parallel to the ground. For a gate with both shimagi and kasagi, the shimagi height and width dimensions should equal the nuki diameter. The space between the shimagi and the nuki should be no less than the height of the nuki (the beam itself, not height above ground, obviously) and no greater than 1-2/3 the height of the nuki. For a gate with shimagi only, the shimagi width should be 10% more than the hashira, and its height should be 1-1/3 the size of the hashira. The ends of the shimagi should touch a line drawn from the outside edge of the hashira at the ground to the end of the nuki (and extended through the horizontal plane of the shimagi). The angles of the ends of the nuki and shimagi are found by cutting according to that same line just described. The length of the kasagi (and the angles of the end cuts for it) are found by drawing a line from the center of the gate at ground level to the outside edge of the nuki, and extending it through the horizontal plane of the kasagi. I have not been able to find the method for determining the curve of the kasagi. I recommend dividing the length into 5ths, with the center 5th level, the next two 5ths (left and right) sloping upward at a 5:1 pitch (that is, for every 5 units of length, elevate 1 unit) giving about an 11 degree angle, and the ends on a 3:2 pitch, giving about a 34 degree angle. Since my gate would be a bit heavier, I recommend no less than 1 mm below ground for every 3 mm above ground. 1 mm blow for every 2 mm above is even better. Dig the holes 35% deeper than needed. Fill that bottom, extra 35% with concrete 24-48 hours before setting the hashira in the ground. While that concrete "foot" is setting, consider standing the hashira in a 5 gallon bucket of water seal - for 24-48 hours. When pouring in the concrete around the hashira, have a mold at the top so that the concrete will rise 10 - 15 cm above ground level. These are all recommendations, made in part from what I have been able to gleen from a variety of resources, including living in Japan for four years. There is a written work, The Five Secret Books of the Master Carpenter, which gives the proportions of the length of the nuki, and the stipulation about the relationship of height and width of the opening that I described above. Although I've seen that reference quoted in English, I was never able to find a copy, not even in Japanese, much less a translation. Cheers.
Feb 8, 2009. 9:14 PMnickmarrone says:
Wow, your instructions are excellent. Thank you!
Sep 16, 2008. 5:44 PMPatented says:
Wow!
Why did you put this instructables in the skewer gun group?
May 2, 2008. 6:12 AMaltomic says:
looking at your backyard I'd say you live in Melbourne. either doncaster or or towards st albans. anywho torii gates have differing dimensions depending on the area of Japan. Just like tatami have different sizes of Jo very cool instructable by the way. and great gate.
Apr 17, 2008. 9:14 PMjoejoerowley says:
Cool! Great Instructable! Very Interesting! Thanks Joe
Jun 12, 2007. 6:35 AMMargot says:
I lived in Japan and was using this to make a smaller scale model for my home garden. I have it nearly finished but I necessarily had to change dimensions. Why? Because your dimensions have errors (?). E.g., Space between Nuki and Shimagi shown as: 180mm. Dimensions for Gakuzuka shown as: 220mm X 130mm X 60mm. In no way would the Gakuzuka accurately fit into the space between the Nuki and the Shimagi. In proportioning for my small torii, I had some difficulty with other dimensions. This is meant to be constructive. The pictured torii is excellent but the given dimensions do not work. If I am wrong, please tell me. Perhaps there are others seeking to construct a torii, scaled down or up; they may be having difficulty. I really like the site! Margot
Nov 5, 2007. 5:02 AMryden says:
Instead of cutting a strip from the topside, what you should do is mark the curvature on the bottom edge and carefully cut of the lower corners. These corners are then attached to the top. Much less work and no spillage. This is how i make S-shaped gate tops.
Nov 6, 2007. 6:30 AMMargot says:
ryden, Thanks for the comment; I had done just that and my torii looks fine. It is painted and ready for installation and celebratiion. Margot
Sep 17, 2006. 5:27 PMBozz says:
You did a great job.
Sep 29, 2006. 6:00 PMdoeric says:
This is awesome, especially for someone who is a Shintoist. *points to self* Do you think you can give me a scale chart, so I can make a mini-torii for my bedroom?
Jan 28, 2007. 7:27 PMwannabesurfin says:
I just built a version with my dad using your design. Dad is a handy at wood work, together we scaled down the dimensions for the smaller yard that I have. We used square posts instead of round ones and it still looks great. So if anyone is thinking of making a smaller version, just scale down the existing dimensions and you should be right. Also, the torii sits above a water feature and has a shiny stell plate as a backdrop. Must admit it looks really good. Another tip is to assemble it before you put the posts in to make sure it all sits in nicely. We measured up the positions of the posts, the height, the level across all dimensions and it assembled so well.
1-40 of 53next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
12
Author:BlueRock
