3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Construct a Japanese Torii Gate for Your Garden
Step 2Hashiras - The Posts
I wanted to build a decent-sized torii so I hunted around for some large posts to use for the Hashiras. I was hoping to use hardwood but found that they are scarce and expensive. I settled for treated pine posts, or Coppers logs as they are known as in Australia, and used 150mm x 3.6m lengths. Although the logs are relatively cheap, about $AU40 each from memory, you have to be selective when choosing them as many are shaped like bananas and others are badly knotted and split. I cut the logs to 3 metre lengths and used a hammer and chisel to start the mortise slots in either side of the posts and then used a large drill to drill through the posts and remove the bulk of the timber from the slots. I spent a bit of time hand-finishing the mortises with hammer and chisel and made sure that the Nuki would slide freely through the slots.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
12
Author:BlueRock
