Constructing Parallel Lines
1,699
19
6
Posted
Introduction: Constructing Parallel Lines
How to construct parallel lines using a straight edge and a compass
Step 1:
Draw a line with you straight edge and put one point on the line and label it 1. Then put one point off the line and label it 2.
Step 2:
Connect point 1 and 2 with a straight edge.
Step 3:
Draw an arch at point 1.
Step 4:
Copy that arch at point 2.
Step 5:
Measure the arch at point 1 with your compass.
Step 6:
Then make an arch the distance of point 1's arch at point 2.
Step 7:
Finally, draw a line with your straight edge through point 2 and where the two archs intersect.
  • Epilog Challenge 9
    Epilog Challenge 9
  • Sew Warm Contest 2018
6 Comments
This technique requires transferring a measurement. The lines will be only as parallel as the accuracy of the measurement. However, since we can construct a perpendicular line that does not require a measurement, we can construct a parallel line by constructing a perpendicular line to a perpendicular line. The net result is two lines that are parallel by construction. Using two triangles is the same idea--the two lines are parallel by definition.
This is exactly what I thought !
Among other things, that's what two triangles are for - drawing parallel lines.
Nicely presented! :)
