Materials you will need:
Clay or other modeling compound (I prefer polymer clay, it stays hard until you bake it)
Sculpting tools (dental tools are nice for real small details)
2 small strips of thin wood (1/4"x2x4 poplar was what I used)
rolling pin
rubber or latex gloves
plastic cups
pastic spoons
silicone compound (I used Smooth-On's Oomoo 25)
plastic compound (I used Smooth-On's Smooth-Cast 300)
Mold Release (I used Mann's Ease Release 200)
4" pvc pipe joint
hobby knife
sandpaper (progressively finer grits recommended)
Spray paints( automobile primer, different colors for the base parts, clear matte coating)
Airbrush (strongly recommended)
enamel paints (I used Testor's from a hobby shop) and brush cleaner
small paintbrushes
cotton swabs, tissue paper, and paper towels are nice for cleanup work
Remove these ads by
Signing UpStep 1Sculpting Original Hexes
When you have enough rolled out (each flat hex took me a little more than one package of FIMO), use a cardboard hex from the game to get the shape right. I cut down with a straight knife then baked the flat hexes. This made sure that anything I add to the hex doesnt mess up the shape of the base. Be careful and try not to leave fingerprints on the pieces like I often did, they will show up on your casted pieces!
The more time you spend on this step, the better your set will look. I am definitely not a sculptor, and even pieces that dont look that great sculpted can look real nice after youve painted them.
The great part about this is if you dont like it, add more clay and try again. If you get something you really like, bake it hard. You can still sculpt and sand the pieces after baking, but its tougher to get what you want. Every little bit of texture will transfer to your casted pieces, so the more work you put in to smooth or rough areas, the more rewarded you will be.
Be warned that undercuts may complicate your molds and cause more wear and tear than theyre worth. The materials I used were fairly forgiving, but I have two molds that started coming apart after about 20 castings.
Quick question: how much of the oomoo did you end up using? I'm assuming you used all the smooth cast? how many pieces did you end up casting?
Thanks
Nicole
Take a look at our experiments with "Cooperative Cataan"
http://www.webrender.net/catan
Right now, it only sorts the main tiles, but I'll be coding in support for seafarers, as well as number tokens, when i get the chance.
Set in progress: http://www.webrender.net/photos/catan5.jpg
Great guide, thanks for the tips!
my 3d catan on flickr
