Introduction: Constructing a Parallel Line
Picture of Constructing a Parallel Line
Lets see how to construct a parallel line.
Step 1: Connect Line and Point
Picture of Connect Line and Point
Step 2: Draw a Circle Around Line
Picture of Draw a Circle Around Line
Step 3: Draw Parallel Line Based on Points and Bottom of Circle.
Picture of Draw Parallel Line Based on Points and Bottom of Circle.
mortenlc (author)2016-10-20
Hi.
I don't think your construction method is correct.
1) The line from the point should be perpenducular to the line CD
2) you should then mark two spots above and below E respectively, on the perpendicular line.
3) from these point you should make parts of circles that intersect, on both sides of the perpendicular line to get two points, from which you can draw the line.
I hope the pictures below explain it.
Best regards, Morten
seamster (author)2016-10-18
Thanks for sharing :)
About This Instructable
83views
0favorites
License:
More by wri531947:Constructing a parallel line
Add instructable to:
