Remove these ads by
Signing UpStep 1Create Mounting Brackets
Once you have a good sized chunk melted, attach the blob to the end of your smooth rod. Its not important at this stage to shape it, simply attach it. Now put the rod to the side for a couple minutes to cool, and start melting more plastic for the next rod or other end.
After a few minutes, the plastic will cool and be easy to work with, yet wont burn your fingers. Shape it so there are 2 tabs, one on each side. These will be where you drill through to attach it to the frame. Once it cools even more, lay it on something flat and hard and flatten the bottom so it will set well on the frame. After it cools completely, rotate one of the brackets so you can get them both aligned perfectly.
Great info. Detailed info.
Thanks for sharing,
Ivan
Rapid Prototyping Info
