Construction of Two Portuguese Style Dinghies (Small Boats)
 by rook999
Contest WinnerFeatured
This project covers the construction of two rowboats that are primarily constructed with three sheets of plywood. The design is not mine. I used a design by Hannu Vartiala, a very generous boat enthusiast who has graciously provided boat plans free of charge on his website.
This project can be found at:
http://koti.kapsi.fi/hvartial/dinghy1/simboii.htm
This is a step-by-step documentation and explanation of the project found on that site. I've tried to simplify some of Hannu's steps for laymen like myself. You will need to refer to that page as you read this Instructable. I won't repeat Hannu's instructions step by step since this is really his design. I'll just explain how I did it, what problems I ran in to and how I got around them.
If the link to Hannu's website ever changes (I discovered that it had) please Google Hannu Vartiala and his new website should come up.
This project tool me about 3 days for the first boat and 2 days for the second.
I will also include tips for oar construction, which Hannu did not cover in his project.
Step 1: Cut the materials
I purchased 1/4" exterior plywood in 4x8 foot sheets.
With the first sheet of plywood you can cut out two side pieces and two transoms (the back end of the boat). Measure carefully and you'll be fine. Refer to Hannu's diagrams for dimensions. The first boat I made was the larger of the two.
I used a skill saw and sawhorses to cut the sides and transoms out of the wood.
Since I was already cutting, I used the last two pieces of plywood to cut the sides for the second, smaller boat sides. I kept the larger remains of both sheets of ply to cut the bottom of the boat from.
To save yourself some time in the long run, I suggest you order your oarlocks now. By the time they reach you the boat may be ready.
I found a decent deal at www.shipstore.com, specifically this item:
http://www.shipstore.com/SS/HTML/ATT/ATT91463.html
This turned out to be the only real hardware I couldn't make myself.
1-40 of 145Next »
rook999 (author) says: Mar 28, 2013. 11:35 AM
I don't have specific dimensions. I ended up buying a metric and standard tape measure from Home Depot so that I could follow along with Hannu's instructions. Both boats were large enough for one average adult to row in.
kjpwnage says: Mar 28, 2013. 10:43 AM
Can I get the dimensions of the smaller boat? I can't understand Hannu's diagrams for my life :/
stormy0314 says: Sep 16, 2010. 11:20 AM
The correct term for the front of the boat is the bow and the correct name for the "bow stick" is the stem. The back end is the stern and that back panel is called the transom. 12 years with the Navy and 40 years in and around the merchant marine plus having a hobby building boats and I never once heard the term prow used except with Viking ships of old. Prow is a lubbers term for bow though.
pfred2 in reply to stormy0314Jun 9, 2012. 2:28 PM
If I built one of these I'd have to add a viking prow. A big carved dragon, that'd be cool!
stormy0314 in reply to pfred2Jun 24, 2012. 1:00 PM
I am thinking of building a kayak for my daughter with a removable dragon head. I would make it removable for taking off if the wind got high enough to blow the kayak off course with the head in place.
rook999 (author) in reply to stormy0314Nov 24, 2010. 3:03 PM
LOL! Thanks!
Clayton H. says: Aug 10, 2010. 8:28 PM
I want to build this boat as a end of summer project, but I'm confused on how to read the diagrams on the other website. How are you suposed to read it? (like the height of the sides of the boat)
rook999 (author) in reply to Clayton H.Aug 15, 2010. 10:31 PM
Refer to the other website. Hannu has his instructions all in the metric system. As an American I regret to admit I had a hard time converting to the metric system as well. I suggest investing in a metric/standard tape measure. That is, it has metric on one side of the tape and the "standard" system on the other side. It will help you convert the measurements. After doing this project, I am convinced that the "standard", or "Imperial" measurement system is silly. The rest of the world is metric, and Americans should just go with it. It's really much simpler.
pfred2 in reply to rook999Jun 9, 2012. 4:08 PM
I got your metric system right here for ya. 12.7x99mm my eye, that's Ma Deuce! She is 50 caliber through and through too. Yankee imperialism keeps the world free. Well, as free as it is ever going to be. Maybe if the rest of the world was more like us it'd be a better place?
Clayton H. in reply to rook999Aug 18, 2010. 4:07 PM
Thanks, I started building the boat around 12:00 and finished the outside fiberglassing about an hour ago. going to try to do the inside and gunwales before dark.
cammers says: Dec 28, 2011. 4:03 AM
Thanks for posting a great ible.
Not only have you inspired me to have a crack at building a boat of my own, but you also made some mistakes - saving me from doing the same. Thanks for including them.
I have just put my first coat of paint on the hull. Can't wait for sea trials. Hope she floats.
Here's a couple of ideas that worked for me and might help future makers:
1. Instead of the tie down strap to bend the sides, I just used rope and tightened it "spanish windlass" style, twisting the top and bottom parts of the rope with a stick. It worked really well tightening top and bottom evenly.
2. Just use resin and hardener for soaking the fibre-glass cloth or mat. There is no need to bulk it with saw dust. That just looks painful. Just paint some resin onto the timber, lay down the cloth, then dab more resin on to wet the cloth. Then use a roller to get the air out. The finish will be pretty smooth especially if you use a woven cloth.
3. To fill holes etc I made a putty from the fibre-glass resin and talcum powder. I found some in my wife's cupboard. It made my workshop smell like an Avon lady, but it works well. Just mix in enough to make a workable consistency.
4. Use Hannu's website. Both for instruction and inspiration. The gallery page has a lot of pictures from other makers and it's full of good ideas.
Thanks again. And to anyone tempted to try one for themselves: Just Do It!
cammers in reply to cammersJan 2, 2012. 7:09 PM
Here are some pictures of my effort.
SIRJAMES09 says: Jul 7, 2011. 12:28 PM
personally I LOVE BASS PRO SHOPS(BPS) & would never shop anywhere else for all the fishing I do.
as far as killing trees to decorate the store, most if not all the trees that I have seen there, are fake trees...the animals are also MOSTLY fake. Fake meaning the heads & such are man made no real animals are killed and/or used to decorate their stores.
I know this because I used to work for BPS in the Headquarters in Springfield MO.
I say used to because stage 4 cancer destroyed any chance I ever had at holding any kind of job ever again.
jsadler1 in reply to SIRJAMES09Sep 18, 2011. 7:52 PM
I pray for your recovery from such a horrid disease. If not recovery then perhaps some joy or other good will be at the end of that battle. So many have gone and yet we have failed to find an easy cure.
SIRJAMES09 in reply to jsadler1Sep 19, 2011. 8:25 AM
TY Sir.
May Allah(swt) be with you always.
geenance says: Sep 18, 2011. 12:19 PM
So what is your best estimate as to the cost to build these boats?
Is it worth it? They look great and fun!
rook999 (author) in reply to geenanceSep 18, 2011. 2:14 PM
I wish I would have kept closer count. It is also hard to say because I had many of the tools and supplies already. I would ball park $200. About $100 per boat. But it would vary from there.
I think it was worth it. If I were to do it again I may forego the oars and find a trolling motor on craigslist.
It also is better to have a place to use them available. It is hard to haul them out to a lake every time you want to use them.
If you do it, send along pictures!
ginchi1739 says: Jul 29, 2011. 8:13 PM
I built two of these several years ago out of regular 1/4 inch ply. Actually I used two layers of plywood. The finished product wasn't a great deal harder to handle than a one ply boat, and I could get both boats in the back of the pickup (turned on their sides). They will also work well with a small trolling motor, or a regular motor up to about 5 HP. The boats lend themselves easily to modifications. I am in the process of building another that I hope will be stronger and speedier than the other two.
SIRJAMES09 says: Jul 7, 2011. 12:40 PM
This looks a wee bit small for fishing, but then again, I'm claustrophobic.
I like the boat! you explained it well, the pics helped tie together any loose ends, & the safety tips, I love it!!!
this is a good boat for toying around in the water, I think maybe you could even add a 3.5 HP outboard (I would NOT go any larger than that tho). This was an enjoyable read.
I think it would be very easy to build a bigger boat based on what you have done here....
You did good!! TY for sharing.
Oh Yeah, if I came across a wee bit harsh about BPS, I appologize. It's just that BPS is my "go to" Store for all my fishing gear.
Easterro says: Nov 23, 2010. 6:48 AM
Thank you for the Instructable - it really fills in some information gaps in Hannu's instructions.
I was curious, how much epoxy did this project take? I'm curious what volume I should purchase.
rook999 (author) in reply to EasterroNov 24, 2010. 3:01 PM
Buy the big one. I used fiberglass, which has two parts to mix together. Home Depot sells a big metal can and a small can. I went through several small cans and finally sprang for the big can and used most of that. Start with the large amount. The amount it takes depends on how thick you lay it in and how wide you put it on and how many coats you put on. Hope that helps!
Easterro in reply to rook999Nov 24, 2010. 5:15 PM
Thanks, that is a big help. I'm starting one this weekend with a buddy. I'll send pics when it's done. Thanks again!
rook999 (author) in reply to EasterroNov 24, 2010. 6:08 PM
Good luck! Wear a respirator, goggles and clothes that cover your skin. That fiberglass is nasty stuff.
grjackson says: Nov 19, 2010. 11:09 AM
I've been meaning to get back on here for some time to thank you for your contribution.
I wasn't terribly confident in following through with this project so I went CHEAP CHEAP! lowest grade plywood and scrap lumber for everything else...
Once I had put the first boat together I was impressed - so I went whole hog with the quality of paint and adhesives I used - three seasons later it's still a sound water tight little rig.
I'd recommend this instructible as a first time boat building venture to anyone!
Thanks again.
rook999 (author) in reply to grjacksonNov 24, 2010. 3:04 PM
Sweet! I'm glad it worked for you. I'd like to see pictures of your boat if you can share them.
grjackson in reply to rook999Nov 24, 2010. 5:20 PM
well this give you an idea of it's capacity - it wasn't a pleasure cruise - but it got us out to the sailboat - three adults and a bit of gear...
rook999 (author) in reply to grjacksonNov 24, 2010. 6:07 PM
Wow! I had oars with mine so I couldn't fit other people in my boats, but with a trolling motor, I guess three could just fit in there. Don't rock the boat!
stormy0314 says: Sep 16, 2010. 11:21 AM
Forgot to say I did enjoy this "ible".
saastamo says: Mar 19, 2010. 1:07 AM
I would prefer talcum as a filler in epoxy. It is more inert than flour or sawdust.
zoltzerino says: Mar 5, 2010. 3:44 PM
 I HAVE THE SAME "CROCS" AS YOUR WIFE!!!!!! </capslock>
Runnerdude says: Nov 26, 2009. 8:54 AM
Is it possible to sail with a right-triangle sail that has only a mast and sheet, no booms or sprits or anything?
TreeFrog in reply to RunnerdudeJan 5, 2010. 4:35 AM
Technically yes, but...
1) It will be really difficult to get the boat to behave in very light winds. There is nothing to hold the sail in the position you want, and you may well get tangled sheets, flogged by the mainsheet etc.
2) you'll probably find that the boat won't point very high into the wind (though a lack of centreboard will be far more of a problem at this point)
3) you don't really want the sail to be a flat triangle, you want the sail to be a curved shape (think of an aeroplane wing cross section). This isn't that hard to do, and you can experiment with plastic sheeting and gaffa tape.
So the answer is a cautious 'well you could..'  Honestly though for the price of a bit of old banister or equivalent and a few extra bits of rope, I'd probably stick with a boom. The extra effort making it would easily pay off in terms of faffing/ cursing time later.
kiffakitty says: Aug 23, 2009. 1:55 PM
does soaking the wood damage the inside?
rook999 (author) in reply to kiffakittyAug 25, 2009. 9:24 PM
No, not once you coat the inside of the boat/wood with some sort of sealant. The hot/warm water temporarily loosens the wood fibers so it can bend. Once it dries, you just coat the inside with some sort of sealant. In my case I used Deck Stain. Paint, or polyurethane or something better would be advisable.
fakedead50 says: Jul 31, 2009. 3:56 PM
What Do U Do About The Cracks On the Side Of The Boat
rbodell says: Jul 9, 2009. 12:56 PM
Like he said, wear long pants and shirt sleeves. tape the sleeves and pants legs around your ankles and wrists. Put a towel over your head and around your neck and tape it too. Any exposed skin cover with Vaseline. If you mess up and leave skin exposed, it will itch like you never itched before. rinse the area with alcohol first them cold water. NEVER HOT WATER. it opens the poors in your skin and the glass gets into them and it itches for days. Be especially careful about breathing the dust.
themonorail says: Jun 21, 2009. 9:55 PM
will the boat work if i don't sand the fiberglass down? i really don't have the finances for a mask and all that business.
rook999 (author) in reply to themonorailJun 22, 2009. 4:12 PM
It should. Try hard to keep the fiberglass smooth as you apply it and you wouldn't need much sanding. You could get away with hand sanding. If you mix something in to the fiberglass, use flour. The sawdust is what makes sanding necessary.
themonorail in reply to rook999Jun 23, 2009. 8:25 PM
great thanks. now about how much weight will this hold?
rook999 (author) in reply to themonorailJun 24, 2009. 7:14 PM
The boats will hold one full sized person about 250 lbs. More or less. Hope that helps!
1-40 of 145Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
