Step 4Bend That Boat!
Mark the locations on the sides of the boat where you will be screwing in the ribs. The first rib, E, will be 30" from the bow. The second, F, will be 56" from the bow. the third rib, G, will be 80" from the bow. (See Hannu's diagrams)
Mark the locations on both sides of the boat.
I screwed all of the ribs to one side of the boat. To get them started. Use long, strong screws. I think I used 2 1/2" wood or drywall screws.
*Note: At this point I want to note a tip that may help you in the long run. I did this on the second boat. Screw in more wood where the transom will end up. I.e., rip a 2X4 in half and attach it verticall to the back ends of both sides. This will end up giving you something to screw the transom to once you get to that point. Otherwise, I have no idea how one is supposed to screw the transom to the sides of the boat.
Now. Carefully bend the side in. Start some screws on the exterior of the boat, and as you tighten in the sides, screw in rib E. Repeat for ribs F and G. They get progressively more difficult to bend in.
After you get the last rib in place, you put the transom on the back and screw it in as well.
You'll note in my pictures that I ended up adding the blocks of wood to the end of the sides as I noted above in order to get something to screw the transom to.
Once you get that transom screwed in, the boat is pretty well stuck together.
I added in some pictures of where my hull started to crack and splinter along rib E. I figured I could sand it down and repair it with fiberglass. Again, soak your wood as I do in boat #2.
comments
Add Comment
rook999 (author)
says:
Add Comment
