Step 8Sanding Fiberglass. yuck.
Because your fiberglass is now hardened and holding the boat together, you can now remove the ribs. If necessary, take out the screws and patch the holes with little pieces of fiberglass.
I have a little Ryobie orbital sander. I used 40 grit paper...a LOT of it, to sand the seams of the boat. I think I used at least 6 packs of the stuff between the two boats. Probably more.
When sanding fiberglass, please always use the following safety precautions:
1) Wear a respirator. You do NOT want microscopic shards of glass in your lungs. Very bad.
2) Wear goggles. You don't want it in your eyes either. Here, I sport Wonka goggles.
3) Wear long sleeved shirts and pants. I figured this out the hard way. You'll itch for days if you do not do this. It's quite uncomfortable.
4) Wear gloves. Same reason.
5) In this picture, I have my jackhammer ear protectors on. the sander is quite loud on 1/4" plywood. I reccommend this.
(Incidentally, I have retrofitted these ear protectors with headphones. I listen to audiobooks when I work. www.audible.com is a great resource for this.)
Ok. Safety taken care of. Sand away. Just make all the seams smooth.
6
comments
Add Comment
rook999 (author)
says:
rook999 (author)
says:
Add Comment
