Consume an Entire Coconut: 9 Products - Zero Waste!
Introduction: Consume an Entire Coconut: 9 Products - Zero Waste!
Consume an Entire Coconut: 9 Products - Zero waste!
Step 1: Gather Your Materials and Supplies
You need,
  • 1 coconut
  • 1 plastic bag
  • eye protection / safety glasses
  • 1 grater
  • 1 carafe or jar
  • 1 sieve or strainer
  • 1 large spoon or ladle
  • 1 hard spatula
  • 1 bowl
  • 1 heavy-bottom pot
  • 1 blender or food processor
  • 1 small heat-safe jar
Optionally, you may want to use
  • 1 broad kitchen knife - to loosen coconut stuck to the shell,
  • 1 splatter screen - if you find the fat splattering out of the pot while making oil.
Step 2: Product #1: Coconut Water
  1. Wrap coconut in plastic bag, and seal the bag closed.
  2. Hold the nut with both hands, and thrust the nut onto a hard surface until cracked.
    Wear eye protection for this step!
  3. Pierce a hole in one corner of the plastic bag to strain the leaking coconut water into the sieve-covered carafe. The sieve will filter out small debris from the coconut water.
    Recycle the plastic bag.
Step 3: Product #2: Coconut Shell Charcoal
  1. Use a knife to separate the nut from the shell - but be careful not to cut yourself!
  2. Remove the fiber strands from the outside of the shells.
  3. To impart a nutty flavor into your food, use the shells as cooking fuel.
    Oil content makes the shells burn like candles, while their fiber content makes them burn hot as coals! I like to cure the shells in the sun a few months before burning. That way, they seem to burn slower.
Step 4: Product #3: Raw, Roasted and Dried Fresh Coconut
  1. Use a vegetable peeler or knife to remove the dark, woody husk from the white, savory nut.
  2. Grate the savory nut,
    • toast it (1 hour @325 degrees F) until golden-brown, or
    • let it dehydrate, or
    • simply store it raw in the fridge and use for consumption and cooking.
    Toasted coconut has a nutty flavor, and can be stored without refrigeration.
Step 5: Products #4: Coconut Milk
  1. Cut white savory nut into smaller pieces.
  2. Place the pieces in the blender.
  3. Cover the nut pieces with hot water.
  4. Blend -  until the water turns pure white and creamy.
  5. Strain the coconut milk from the husk mixture. Voila - coconut milk!
    Use the
    • milk for consumption and cooking, and/or
    • the curd for oil (Product #8).
Step 6: Product #5: Coconut Cream
  1. Let the milk stand for one hour.
  2. Skim the cream off of the top of the milk.
    Refrigerate the milk and \ or cream if you're not using it immediately, or it will spoil.
Step 7: Product #6: Hydrating Body Rinse
  1. Use the residual water as a body rinse, or manicure/pedicure soaking solution.
    We freeze bags of coconut body rinse, and refill a carafe kept in the bathroom.
    After washing, we rinse with the coconut water, which hydrates and softens our skin.
    It smells so good!
Step 8: Product #7: Raw Body Scrub
  1. Use the leftover husk as a raw body scrub.
    The milk content hydrates and soothes the skin, while the nut gently exfoliates.
Step 9: Products #8: Coconut Oil
  1. Set the milk where it won't be disturbed for 24 hours.
  2. Skim the fat off the top of the separated milk into a pot.
  3. Boil the skimmed fat until the it turns brown and the oil runs clear.
    Note: The fat will form a solid patty. My daughter thinks it looks like a hamburger.
  4. Pour off the oil, into a heat-safe vessel.
Step 10: Product #9: Moisturizing Body Scrub
  1. Scrape the toasted husk (hamburger) from the pot, and
  2. Break it into chunks.
  3. Cool the body scrub.
    Enough essential coconut oil will remain in the scrub to rehydrate the skin.
    The mildly abrasive husk exfoliates the dead skin cells.
    It smells good, too!
    • Science of Cooking
      Science of Cooking
    • Trash to Treasure
      Trash to Treasure
    • Paper Contest 2018
      Paper Contest 2018
    I tried d coconut oil exact and it came out well, thanks for sharing the method.
    I come from Kerala - ' the land of coconut ' - now famous as ' God's own country '.I just wanted to add that every part of the tree also is used for various things.Lovely things are made out of the shell.The trunk is used as beams in making huts,the leaves woven and used for thatching.Toddy [ local liquor] is another item.Jaggery [like brown sugar] is used in place of sugar.The husk[ fiber outside the shell] is made into ropes and mats and handbags to mention just a few.Most of our food has coconut as an ingredient. I think you need to visit KERALA.
    I usually get the water out by drilling through the three eyes and draining. This way there won't be as much fiber from the outside as in the bag method.
    But I then use a variant of the bag method for opening it. Except we do it a more fun way. We throw it downward onto a cement driveway. :-)
    I find you can usually get a corkscrew screwed in to the nut and pull it out, though if it's not a sturdy corkscrew it'll just create a new and strange problem...
