3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Quick and Easy Shelves for Shipping Container
Build your own shelving for a shipping container.
They are very strong and can be used as regular shelves or as stock racks.
You can even use them for workbenches if you put them at the right height.
The uprights are "unistrut" u-channel that hang from the container's upper tiedown rings.
The shelf support brackets are as simple as possible, just a flat plate or board with two holes in one end.
They bolt onto "springnuts" a.k.a. "diamond nuts" inserted in the unistrut.
Here's how to get the wood for your shelves very cheap.
In this photo Michael Kearney puts freshly linseeded boards up.
WARNING:
The brackets must be bolted firmly. When the wood dries and shrinks the bolts must be tightened again. Otherwise these shelves are a deadly time-bomb booby trap.
Step 1Shelves of Death
Shelves of Death
A year later, I found out a potential danger of these shelves.
After about a year they tended to sag a little bit. The bolts gripping the brackets slipped a bit because the wood shrank. I didn't think much of it.
Then the end-grain wood failed and the brackets collapsed, dumping everything into the middle of the container. Damn. I'm glad I wasn't standing under that stuff.
So then I went around tightening the bolts on the remaining brackets. It would be good to add some kind of a cheek plate to the brackets so they couldn't fail in this way.
Check out this collection of other dumb mistakes I've made.
23 comments
Jul 3, 2008. 9:38 AMshooby says:
This is my dream container, as a house addition. It's only a 20 foot, but it'd make a great study/reading room to be placed on top of a 40' container.
Oct 2, 2011. 4:30 AMzholy says:
Actually ... you MUST NOT place a 20f on a 40f container - unless you modify the 40f to support the 20f. The roof would not withstand the pressure of the 20f.
You can stack 20 on 20 ... and 40 on 40 only !!!
Oct 2, 2011. 6:43 AMshooby says:
Of course....corner to corner only.
Mar 7, 2011. 7:20 PMakgooseman says:
Saw a guy with eight containers stacked two high in two parallel rows about 40' apart. He placed trusses over the containers and roofed it in and closed off the open ends. Cut a couple holes in the sides for easy access to the inside of several containers, build steps. Made a great shop area. Very sturdy, quite inexpensive. He tied it all to the ground with steel cable and deep pilings so it wouldn't blow away.
Jul 25, 2010. 6:29 AMadam_francese says:
Wow, great project... but I don't know how quick or easy this would be for someone who is not a wood worker. Also you make a little more work for yourself by having to modify the container (to hold the bracket) and also risk rust and weak points. There is actually a product for this.. visit www.out-backstorage.com Look for "Storage Container Shelving" The only wood working involved is cutting the length of the shelf and the brackets latch to the existing interior latch holes along the top of most steel storage containers. Not to mention they are super easy to install just add more brackets to increase capacity! Out-back Storage is also a great source for purchasing and renting containers in New England.
Sep 24, 2008. 3:56 PMcorradini says:
Speaking as a guy who spent a good chunk yesterday and today mounting channel strut to the walls of a shipping container (seriously)... ...AND who's done rather a lot of woodworking... I don't think wood "shrinkage" is the problem. When you put a load on these wooden shelf brackets, you're putting the lower bolt-hole in compression (against rather a lot of wood) and the upper bolt-hole in tension. Put more simply -- you've just created a simple lever that's trying to pivot around the bottom bolt, and use the torque of the length of the shelf support as a 'force multiplier', to rip through the wood along the grain-line -- and you've only got roughly (1.675" - (.375 bolts?) / 2), or 0.675" of wood at the top bolt to support your load. For a gang with a waterjet cutter, who make your own strut-nuts? -- DANG! You should check out basic statics, fulcrum loading, stuff like that! >;-) (I get to kid -- I have ZERO engineering training, and my degrees are both in business -- I'm self-taught, and recently.) More practically: use side plates. Home Depot sells 2-hole straight plates, right under the unistrut, for cheap. Or - use the waterjet., make yer own. Even way mo-betta-mo-smahtah? USE STRUT FOR THE HORIZONTALS! ;-) Cool project though. Where do you get a waterjet?
Mar 1, 2008. 5:19 PMbumpus says:
how much does the average shipping container cost, im thinking about an underground bunker...
Mar 18, 2008. 5:12 PMnedfunnell says:
You can get them in Dallas for $1850-2000, but it's as-is where-is. You'll need a friend with a truck and 40' trailer. Also, this is for not-the-greatest-quality containers, not inspected or warranted. That doesn't mean that they're terrible, just not perfect.
Jan 21, 2008. 9:15 AMstasterisk says:
Do you have pictures of the finished shelves? Is step 1 what "sealing" looks like? Why are spring nuts good?
Jan 20, 2008. 11:27 PM0.775volts says:
If you look into shipping containers and the like, you may find some with E-rail in them. these manifest themselves as strips of rectangular slots attached securely to the walls at different intervals. this is a strapping system for securing goods to the walls via straps and load bars. I would recommend that you find a container with e-rail if possible, as it makes the inside an (even more) modular playground.
Jan 20, 2008. 2:13 PMWeissensteinburg says:
It's funny you post this..i've been thinking lately how much I want to make a shipping container home when i'm older. Where'd you get yours?
Jan 20, 2008. 5:22 PMkillerjackalope says:
ha you understand the calling then, Already own two 40' containers, fully sealed, dry with good boards on the floor, they hold our family's stuff at the minute but someday they weill be my house/workshop where I may build my more ambitious and dangerous contraptions, if I get the better job I'll be making enough to have money for what I suspect could be a real world first, rmember the JATO stories...
Jan 20, 2008. 7:32 PMWeissensteinburg says:
Where'd you get them from?
Jan 20, 2008. 8:33 PMkillerjackalope says:
My dad owned a tyre fitting business in the harbour and we used hacked u containers as workshops, a depot and an ol insulated one as a room for bulletproofing tyres, It's form of solid filling with liquis polyurethane so keeping it hot makes it run much faster... Those two were simply for shipping 800 quid for two and we did the guys tyres on his car and I fixed a hole in his exhaust... So I actually know a bit about this subject, my plan is two 40' containers on top of eachother with stairs, kitchen behind them room upstairs and a big room downstairs... and yes the empty whiskey bottle, engine parts and odd mechanical junk lying around count as furniture lol
Jan 20, 2008. 7:56 PMWeissensteinburg says:
Well I currently live in Home of the Old People and Snowbirds (Florida)...but who knows where i'll be come house raising time!
Jan 21, 2008. 12:58 AMdchall8 says:
Do a search on 'Gypsy Wagon' to get some ideas. The Society for Creative Anachronism (SCA) folks are reasonably expert in compact living. For more ideas you can search 'private railroad cars.' These people customize old private train cars in every way imaginable. If you live in the Florida Panhandle, you might look in the Mobile area. Or your closest shipping port.
Jan 21, 2008. 10:26 AMWeissensteinburg says:
Well when I build a house, I plan for it to be full size - using maybe four containers. Big enough for a family =]
Jan 21, 2008. 12:15 PMdchall8 says:
The standard 45 foot size (there are other standard sizes) has an interior area of about 345 square feet without walls or insulation. If you put a minimal 4 inches of insulation and Sheetrock on the walls the area drops to 310 square feet. The problem with decorating one is the max width interior is 7 feet (with walls). Certainly a family could live in one, but there would be compromises versus what we are used to. Of course I have a friend who lives in a camper so a container would be a major upgrade for him. There are a lot of abandoned rail cars around the southwest. Transportation is the problem with them as the trucks deteriorate with time. They would probably have to be moved on a flatbed.
We used one in a testing project back in the 80s and found it possible to punch holes in the aluminum skin if you were careless. It is much more sturdy than normal housing siding - just not impervious to puncture.
Wikipedia on shipping container architecture
Jan 21, 2008. 1:30 PMWeissensteinburg says:
yes...but when four are connected, you get 1200+ square feet, which is a normal. I've been doing research on them, reading plenty of articles on homes and apartments made out of them.
Jan 20, 2008. 2:54 PMrandofo says:
Fell off the back of a truck.
Jan 20, 2008. 5:41 PMGorillazMiko says:
That was my truck.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
1250
Author:TimAnderson
Tim Anderson is the author of the "Heirloom Technology" column in Make Magazine. He is co-founder of www.zcorp.com, manufacturers of "3D Printer" output devices. His detailed drawings of traditional ...
more »
