3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Contemporary Street Number Plaque
Step 3Layout and Drilling
Layout and Drilling
Now, this step will vary widely depending on the style of house number that you choose, the means by which that number is attached, and how you plan on attaching this to your house. Also, since I left the protective film on this side, I could mark my drilling points directly on the Lexan. Pretty convenient.
The numbers I bought had threaded sockets on the back to attach metal studs which were intended to be glued into holes in my house. I tried this approach once. Strife, pain, profanity and crookedness ran rampant. I don't suggest it. However, those threaded sockets made them very easy to attach to my Lexan with 3/8" #8 screws. I simply used the included templates to lay out my guides for drilling.
As far as laying out the holes to attach it to the house, I specifically lined everything up in such a way that I would only have to drill into the mortar between the bricks. Since I'm mounting this on brickwork, this is useful for a few reasons:
1) Its much easier to line everything up
2) The mortar is easy to drill through. Have you ever tried drilling into a brick?! I did one time. I died a little that day.
3) If you make a mistake or have to move your house numbers, its pretty easy to fill in the holes in mortar.
Once I had everything marked, I grabbed the appropriate drill bit and went to drilling. This part is easy, but you have to be extremely accurate if you want everything to look straight and neat.
NOTE: When drilling your holes, make sure to drill them just a little bit large. Polycarbonate has a tendency to expand and contract with weather changes, so you want to give it some wiggle room.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
8
Author:cornflake_81
I have a penchant for anything that requires tinkering or fiddling. I unfortunately live in a newer home that requires little repair or maintenance, so I mostly sit around waiting for something to br...
more »
