3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Contemporary Street Number Plaque
Step 4Hardware and Sticking it to the Wall
Once everything was drilled, I took the protective film off and attached the numbers. I took a lot of care during this step as to not scratch the thing all to hell.
After the numbers we're attached, I turned my attention to actually making it stick to the house. I used lead shields, which are little lead anchors designed attach stuff to brick or mortar. Just like a drywall anchor, you just drill the appropriate sized hole and tap it in with a hammer. Now, I could just slap it on the wall as is, but I wanted to make it sort of "float" out from the wall just a smidge. I found these little aluminum spacers in the "Stuff You'll Never Need" drawer in the fastener aisle at Home Depot. They just go in between the Lexan and the wall. When tightening down the screws, it bears noting that if you torque everything down too tight, the Lexan will warp a bit. If that happens, just back it off a bit until it straightens out.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
8
Author:cornflake_81
I have a penchant for anything that requires tinkering or fiddling. I unfortunately live in a newer home that requires little repair or maintenance, so I mostly sit around waiting for something to br...
more »
