Contemporary railings using skateboard wheels
 by mart!
FeaturedContest Winner
My first instructable!!!
After getting really expensive quotes for my railings, i decided to make my own. i got inspired by my skateboard wheels, i liked how the light shined through. i purchased some stock steel channels to use as posts, machined the wheels to hold the glass panes and then took measurements about 17 different times and ordered the glass. everything fit perfectly and i saved 6000$.
You might not need railings, but maybe this will give you other ideas!
Step 1: Posts
i used 3 inch channels to make the posts. check with your local building codes, but here railings have to be 42 inch high. i made the posts 40 inch as the glass pane goes 2 inches higher than the posts. make sure you're installing them in something solid!
colelemi says: Mar 6, 2013. 1:57 PM
My son would love something like this in his room. Instead of railings, I could do some sort of hook system with the wheels. But I like this concept, something he could do when he moves out.
barrym says: Feb 27, 2013. 2:35 PM
Very creative use of common metal channel. You mentioned you saved $6k, but can you share the total cost of materials?
mart! (author) in reply to barrymFeb 28, 2013. 10:51 AM
thanks - i havent kept the receipts but the wheels where about 100$, hardware about 100$, 60ft of channel - i *think* that was about 70$ per 20ft but not 100% sure. the glass panes cost me somewhere between 450 and 600$, i had a good deal on that since i went trough a friend's company who buys a lot of glass so they get a special discount.
the rest was just labor time. took one day to do the wheels, and about 2 or 3 days of measuring everything 17 times. once everything was in place, the glass took longer to uncrate than to install.
barrym in reply to mart!Mar 1, 2013. 10:35 AM
Very informative, thank you.
EnergyHandyman says: Jun 10, 2012. 6:29 PM
You need to order the parts from a 3d printer place next time,
Or a wheel mfg.
But I know making it yourself felt good. Very awesome engineering.
mart! (author) in reply to EnergyHandymanJun 11, 2012. 7:28 AM
no, i wanted to learn something new - first time on the lathe :)
you dont learn much by paying someone else to do something for you. if everybody did that, we wouldnt have this website!!!
that said, the 40 wheels cost me a tad under 100$ shipped to my door. i tried contacting a wheel co. but they never replied, i doubt they would have given me a better price, a set of 4 from a known brand is usually about 38$. And i'm pretty sure 3d printing would have cost a lot more...
i wanted skateboard wheels because they actually mean something to me, more than any other generic manufactured part...
stuie25 says: Jun 10, 2012. 6:15 PM
curious about the bolts, did you tap the holes in the steel channel, it looks like a hex bolt on a flat washer then the wheel, is the wheel actually cut right in half?
mart! (author) in reply to stuie25Jun 11, 2012. 7:18 AM
see "technical" drawing in step 2!
clazman says: Jun 10, 2012. 11:06 AM
Using steel channels weren't you concerned with oxidation? Wouldn't aluminum extrusions been a better choice? Aluminum, however, would give a different appearance than the darker steel.
I think that the lock washers may be unnecessary. Are they actually being compressed? there shouldn't be any tendency for the nuts to loosen, no building vibrations, i.e. heavy nearby traffic ; ). "Locktite" on the threads?
But three cheers to a nicely thought out and artistic design!!! ; )
mart! (author) in reply to clazmanJun 11, 2012. 7:15 AM
i wiped everything with rust inhibitor. its pretty much like oiling wood instead of varnishing it, you keep the original material's feel to the touch. i did the same for my fireplace mantel and i just have to give it a wipe every year to keep it looking nice. maybe i can make an instructable for that...
they're not lock washers, just regular washers used to spread the weight wider on the wheel face. any vibrations are suppressed by the urethane wheel.
the house is very minimalistic, very precise and almost chirurgical. i used wood, iron and concrete to counterbalance it all. the goal was to use these materials in the most original form possible, including their flaws; some iron posts have yellow pen markings on them, some are slightly stained or rusted. i used cedar to cover a wall in the kitchen, its full of knots and imperfections, its not coated with anything so it will change color with time. the concrete floors have marks, cracks and stains that change with time... its not some kind of ideology or dogma, its just some design guidelines i set myself when i started to design the house. just a path layed out so that it doesnt end up looking all over the place!
AND, it also kept costs down a lot!
Oscelot in reply to clazmanJun 10, 2012. 1:41 PM
I think a quick coat of rustoleum would have taken care of that.. pretty sure they make it in clear now.
stevet47 says: Jun 10, 2012. 11:39 AM
This is gorgeous, great work! I might have to steal your idea some day.
Microbe in reply to stevet47Jun 10, 2012. 5:55 PM
The whole purpose of Instructables is so that you don't have to "steal" the idea...it is freely given :o)
fmhiggins says: Jun 10, 2012. 9:53 AM
What did you use to coat your steel posts?
Matt Carl says: Jun 10, 2012. 9:02 AM
Wow, absolutely amazing results! would love to see the rest of your house's design!
laferte says: Jun 10, 2012. 7:43 AM
It looks SO good! That is really clever engineering!
megaduty says: Jun 7, 2012. 7:42 AM
Voted for you.
Very clean looking results; with led lights at night this is awesome!
mart! (author) says: Jun 7, 2012. 5:52 AM
whoa - thanks for all the nice comments, they help to motivate me to finish this d*** house!! :D
cheers!
bobzjr says: Jun 6, 2012. 8:22 PM
That is brutally elegant! I am very impressed. Inspiring.
ClaudioDonate says: Jun 6, 2012. 4:11 PM
Men, what a nice solution! Looks great! Congrats to you, my friend, very clever idea.
corbuwannabe says: Jun 6, 2012. 3:22 PM
That is very minimalistic and industrial looking....thanks for posting!
thebunnykingofnowhere says: Jun 6, 2012. 1:51 PM
Amazingly beautiful use of materials. Well done
canida says: Jun 5, 2012. 10:24 AM
Wow, this is gorgeous!
mikeasaurus says: Jun 4, 2012. 7:07 PM
Clever solution, and the results look great! Thanks for posting this!
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
