loading
Step 2: tests, plans and machining.
i decided to do a little test as i wasnt sure how urethane wheels would react on the lathe. turned out its like butter, you just need to crank up the speed as fast as possible otherwise the cut isnt clean. once i knew it would work, i ordered 10 sets of wheels from a wholesale place.
i decided to use 6mm thick tempered glass. call the glass shop and ask what size holes they can make before you start... i got lucky... i machined the wheels at 38mm, and they could do 40mm holes in the glass. the 2 mm difference made everything fit much better!
i made a tool to hold the wheel in the lathe from its center, then the first step was to make one side flat. that side will be the back. i did all 38 wheels, then moved on to the next step. i grooved the front part of the wheel where the washer will sit. i then cut the wheel removing the entire front part, and then machined it so that the center diameter is 38mm and 6mm wide.
it took me about 8 hours to make all 38 wheels, and at least 1 to clean the entire shop... urethane dust is sorta sticky... oh yeah, wear a mask when you machine it!
<p>For $1000's worth of materials, that's a pretty fancy schmancy railing you ended up with. You can't put a price on uniqueness and creativity. Well done.</p>
My son would love something like this in his room. Instead of <a href="http://www.kandsrailings.ca" rel="nofollow">railings</a>, I could do some sort of hook system with the wheels. But I like this concept, something he could do when he moves out.
Very creative use of common metal channel. You mentioned you saved $6k, but can you share the total cost of materials?
thanks - i havent kept the receipts but the wheels where about 100$, hardware about 100$, 60ft of channel - i *think* that was about 70$ per 20ft but not 100% sure. the glass panes cost me somewhere between 450 and 600$, i had a good deal on that since i went trough a friend's company who buys a lot of glass so they get a special discount. <br>the rest was just labor time. took one day to do the wheels, and about 2 or 3 days of measuring everything 17 times. once everything was in place, the glass took longer to uncrate than to install.
Very informative, thank you.
You need to order the parts from a 3d printer place next time, <br> <br>Or a wheel mfg. <br> <br>But I know making it yourself felt good. Very awesome engineering.
no, i wanted to learn something new - first time on the lathe :) <br>you dont learn much by paying someone else to do something for you. if everybody did that, we wouldnt have this website!!! <br> <br>that said, the 40 wheels cost me a tad under 100$ shipped to my door. i tried contacting a wheel co. but they never replied, i doubt they would have given me a better price, a set of 4 from a known brand is usually about 38$. And i'm pretty sure 3d printing would have cost a lot more... <br> <br>i wanted skateboard wheels because they actually mean something to me, more than any other generic manufactured part...
curious about the bolts, did you tap the holes in the steel channel, it looks like a hex bolt on a flat washer then the wheel, is the wheel actually cut right in half?
see &quot;technical&quot; drawing in step 2!
Using steel channels weren't you concerned with oxidation? Wouldn't aluminum extrusions been a better choice? Aluminum, however, would give a different appearance than the darker steel. <br> <br>I think that the lock washers may be unnecessary. Are they actually being compressed? there shouldn't be any tendency for the nuts to loosen, no building vibrations, i.e. heavy nearby traffic ; ). &quot;Locktite&quot; on the threads? <br> <br>But three cheers to a nicely thought out and artistic design!!! ; )
i wiped everything with rust inhibitor. its pretty much like oiling wood instead of varnishing it, you keep the original material's feel to the touch. i did the same for my fireplace mantel and i just have to give it a wipe every year to keep it looking nice. maybe i can make an instructable for that... <br> <br>they're not lock washers, just regular washers used to spread the weight wider on the wheel face. any vibrations are suppressed by the urethane wheel. <br> <br>the house is very minimalistic, very precise and almost chirurgical. i used wood, iron and concrete to counterbalance it all. the goal was to use these materials in the most original form possible, including their flaws; some iron posts have yellow pen markings on them, some are slightly stained or rusted. i used cedar to cover a wall in the kitchen, its full of knots and imperfections, its not coated with anything so it will change color with time. the concrete floors have marks, cracks and stains that change with time... its not some kind of ideology or dogma, its just some design guidelines i set myself when i started to design the house. just a path layed out so that it doesnt end up looking all over the place! <br> <br>AND, it also kept costs down a lot! <br>
I think a quick coat of rustoleum would have taken care of that.. pretty sure they make it in clear now.
This is gorgeous, great work! I might have to steal your idea some day.
The whole purpose of Instructables is so that you don't have to &quot;steal&quot; the idea...it is freely given :o)
What did you use to coat your steel posts?
Wow, absolutely amazing results! would love to see the rest of your house's design!
It looks SO good! That is really clever engineering!
Voted for you.
Very clean looking results; with led lights at night this is awesome!
whoa - thanks for all the nice comments, they help to motivate me to finish this d*** house!! :D <br>cheers!
That is brutally elegant! I am very impressed. Inspiring.
Men, what a nice solution! Looks great! Congrats to you, my friend, very clever idea.
That is very minimalistic and industrial looking....thanks for posting!
Amazingly beautiful use of materials. Well done
Wow, this is gorgeous!
Clever solution, and the results look great! Thanks for posting this!
About This Instructable
18,215views
66favorites
License:
Bio: Graphic designer for almost 20 years. dirty hands = happy hands
More by mart!:Screen Printing Photo Emulsion Light Table Contemporary Rocking Chair Contemporary Fireplace Mantel
Add instructable to:
