There are two software programs to go with this robotic project. One permits the calibration, in sequence, of the three sensors used. The other provides a state-based control program to define the robot's behavior. If one watches the attached video, one will see that the robot is able to do at least some navigation around obstacles. This instructable is my entry for the iRobot Create Challenge.
Remove these ads by
Signing UpStep 1Gather Hardware Required
(1) iRobot Create robot w/battery and charger
(1) iRobot Command Module for Create
(My thanks to the iRobot Create Challenge for providing the above via their mini-scholarship program, and for prompt replacement of a failed Command Module.)
(1) audio recording device (I used an Olympus WS-320M, ~$150.00)
(2) Element Direct eProto boards ($4.95 ea.)
(1) Element Direct eDisplay board ($19.95)
(1) DB-9 male solder-cup connector (~$2.00)
(1) DB-9 female solder-cup connector (~$2.00)
(1) piece perfboard (~$4.00)
(1) 20x30" piece of foamcore, white (~$5.00)
(3) Cadmium sulfide (CdS) photo-resistive cells (~$2.50 for a pack of five)
(3) 5K ohm potentiometers (~$1.00 ea.)
(3) PC terminal strips, two position (~$3.00 per pack of four)
Expendable supplies:
(1) roll gaffer's tape (~$12.00)
(1) package velcro, adhesive backed (~$15.00)
(1) tube solder (~$5.00)
(3) rolls 22 gauge hook-up wire (~$12.00)
Tools used:
(1) Soldering iron
(1) Wire-stripper
(1) Diagonal cutter
(1) Needle-nose pliers
(1) Volt-ohm-meter
(1) X-Acto Mat Cutter
(1) Desktop computer w/USB cable for programming the Command Module
comments
Add Comment
Add Comment
