Introduction: Continuos Rotation Servo (The Easy Way!)
Picture of Continuos Rotation Servo (The Easy Way!)
This instructable is to teach you how to make a continuos rotation servo. I am useing a hpi sf-1 but you can use any servo that is 180 degrees.
Step 1: The Opening of Your Servo
To open many servos there are 4 screws in the bottom. Unscrew those then take off the arm or head of the servo by removing a screw.
Step 2:
Now you need to find a different color gear and in my case it is black. There is a tab on it. Remove the gear then remove the tab. After there should be a plus sign on the bottom of that gear and you need to get rid of it by slowly removing it with a drill
Step 3:
Now an arduino is handy for this step. You need to center out the potentiometer. Use an arduino with a servo program and set the output to 0. Now make it so the motor stops spinning by adjusting the potentiometer. After that use a bead of hot glue or superglue if you want it to be permanent.
Step 4:
Now it should rotate continusly If you have questions leave me a comment.
blackbeard23 (author)2016-03-06
Not at the moment. I will get some more soon
DIY Hacks and How Tos (author)2016-03-05
Nice hack. Do you have any more pictures of the process to help illustrate.
About This Instructable
1,007views
25favorites
License:
More by blackbeard23:Continuos Rotation Servo (The Easy Way!)IPod Speaker(cheep And Easy)
Add instructable to:
