Control Any Devices Using Raspberry PI and PCF8574, Relay Module
3,354
64
Posted
Introduction: Control Any Devices Using Raspberry PI and PCF8574, Relay Module
This guide shows you how to use PCF8574 with Raspberry PI. The PCF8574 is a 8 bits I/O port expander that uses the I2C bus. To the PCF8574 I will connect the relay module, this will allow control of the electrical device from the Raspberry PI. I will also show an example how to write a program to handle PCF8574 in C++ on Linux.
This article can also see here:
Control any devices using Raspberry PI and PCF8574, relay module
Step 1: Components
Components I used in this example.
Step 2: Schematic
Diagram of connecting Raspberry PI with PCF8574 8bits I/O expander.
Step 3: Enable I2C Interface on the Raspberry Pi
At first we need to enable I2C bus on Raspberry Pi. For this purpose, we use the following command.
	sudo raspi-config
  • Select Interfacing Options
  • Select P5 I2C
  • Select Yes
Step 4: Install Utilities
	sudo apt-get update
	sudo apt-get install -y i2c-tools
We add user pi to group i2c.
	sudo adduser pi i2c
After installation we restart the Raspberry Pi.
	sudo shutdown -r now
Step 5: Checking I2C Bus and PCF8574
First, let's scan the i2c bus. In this step, you must already have a PCF8574 connected,
otherwise the scanner will not find anything.
	i2cdetect -y 1
My PCF8574 has an address 0x38. Now let's test the expander.
0x38 is the address of the PCF8574 expander.
0xf0 is the output state as we set, 4 bits in HIGH and 4 bits in LOW.
	i2cset -y 1 0x38 0xf0
We can also read the state of PCF8574 I/O ports.
	i2cget -y 1 0x38
Step 6: Software
Below simple program to handle PCF8574, written in C++.
#include <stdio.h>
#include <time.h>
#include <string>
#include <wiringPi.h>
#include <pcf8574.h>
using namespace std;
int main (int argc, char *argv[]){
	printf("Raspberry Pi\n");
	printf("http://geek.adachsoft.com/\n");
        wiringPiSetup();
	pcf8574Setup(100, 0x38);
	for (int i = 0; i < 8; ++i){
    		pinMode(100 + i, OUTPUT);
        int b=0;
        while( 1==1 ){
                printf("LOOP %u\n", b);
                    digitalWrite(100 + i, i==b ? 0 : 1);
                b++;
		if( b >= 8 ) b=0;
		delay(1000);
	delay(1000);
	digitalWrite(100 + 0, 0);
	delay(1000);
        digitalWrite(100 + 0, 1);
	return 0;
To compile and launch it, use the following command.
	g++ pcf8574.cpp -o pcf8574 -lwiringPi -std=c++11
	./pcf8574
Download source code: pcf8574.cpp
wwwGoogle pluseTwitter
    • Microcontroller Contest
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    2 Comments
