Introduction: Control Arduino Using Android App
Picture of Control Arduino Using Android App
In this instructables I'm going to explain how to control the arduino IO pins using an android app, which we'll write here.
The communication will be over ethernet and we'll use the GET request to activate the IO's.
Let's get started!
Step 1: Parts
Picture of Parts
For this instructables you'll need several parts.
  • An arduino
  • An android smartphone or tablet (I'm using android 5.0.1)
  • An ethernet shield
  • 3 Led's
  • 3 220 ohm resistors
  • Some jumper wires
  • a breadboard
  • A computer with android studio installed
Step 2: The Ethernet Shield
Picture of The Ethernet Shield
I got this Ethernet shield from gearbest.com.
It worked instantly on my arduino mega (also from gearbest.com)
On the shield you have 2 SPI devices. The SD card reader and the W5100 IC for Ethernet.
In this instructables we'll only be using the Ethernet part.
Step 3: Schema
Picture of Schema
We need to connect the 3 led's to the arduino. You can use every pin except pin 0, 1, 10 to 13 and 50 to 53.
I'm using pin 22, pin 23 and pin 24.
You also need to connect your arduino to your local network. Internet isn't needed.
Step 4: Arduino Sketch
Picture of Arduino Sketch
For the arduino sketch I started from the example webserver sketch.
I tried documenting every thing, but if you have a question feel free to ask!
#include <SPI.h>
#include <Ethernet.h>
// Set the MAC address
byte mac[] = {0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED};
// Set the IP address
IPAddress ip(192, 168, 1, 177);
// Start a server at port 80 (http)
EthernetServer server(80);
void setup() {
  // Open serial communications
  Serial.begin(9600);
  // start the Ethernet connection and the server
  Ethernet.begin(mac, ip);
  server.begin();
  // Pin 22 - 24 output (leds)
  pinMode(22, OUTPUT);
  pinMode(23, OUTPUT);
  pinMode(24, OUTPUT);
void loop() {
  // Check if client connected
  EthernetClient client = server.available();
  if (client) { // If there is a client...
    boolean currentLineIsBlank = true;
    String buffer = ""; // A buffer for the GET request
    while (client.connected()) {
      if (client.available()) {
        char c = client.read();// Read the data of the client
        buffer += c; // Store the data in a buffer
        if (c == '\n' && currentLineIsBlank) {// if 2x new line ==> Request ended
          // send a standard http response header
          client.println("HTTP/1.1 200 OK");
          client.println("Content-Type: text/html");
          client.println("Connection: close");
          client.println(); // Blank line ==> end response
          break;
        if (c == '\n') { // if New line
          buffer = "";  // Clear buffer
        } else if (c == '\r') { // If cariage return...
          //Read in the buffer if there was send "GET /?..."
          if(buffer.indexOf("GET /?led1=1")>=0) { // If led1 = 1
            digitalWrite(24, HIGH); // led 1 > on
          if(buffer.indexOf("GET /?led1=0")>=0) { // If led1 = 0
            digitalWrite(24, LOW); // led 1 > off
          if(buffer.indexOf("GET /?led2=1")>=0) { // If led2 = 1
            digitalWrite(22, HIGH); // led 2 > on
          if(buffer.indexOf("GET /?led2=0")>=0) { // If led2 = 0
            digitalWrite(22, LOW); // led 2 > off
          if(buffer.indexOf("GET /?led3=1")>=0) { // If led3 = 1
            digitalWrite(23, HIGH); // led 3 > on
          if(buffer.indexOf("GET /?led3=0")>=0) { // If led3 = 0
            digitalWrite(23, LOW); // led 3 > off
        } else {
          currentLineIsBlank = false;
    delay(1);
    client.stop();
That was the code for on the arduino.
Pretty easy, right? Let's go to the app!
Step 5: App Layout
Picture of App Layout
For creating an android studio project I'll redirect you here. The start is the same, choose a name and create the main activity, but after you deleted the "hello world" textview you need to add 3 buttons of any kind. I'm using a switch, a toggle button and a normal button, but you can choose what you like most.
Note:
When you get a render error, on the top of the window, change Apptheme to Appcompat.NoActionBar
! Attention !
A normal button will only lit it's led when pressed. The led will go out when the button is released.
In res/values/styles.xml you need to change parent to: "Theme.Appcompat.NoActionBar"
Ok, now we can start coding the app!
Step 6: App Coding
Picture of App Coding
For coding the app, I made it easier for you. You need to copy this code to MainActivity.java and change package laurens_wuyts.arduinoiocontrol to company.appname.
package laurens_wuyts.arduinoiocontrol;
import android.app.Activity;
import android.os.AsyncTask;
import android.support.v7.app.ActionBarActivity;
import android.os.Bundle;
import android.view.Menu;
import android.view.MenuItem;
import android.view.MotionEvent;
import android.view.View;
import android.widget.Button;
import android.widget.CompoundButton;
import android.widget.Switch;
import android.widget.ToggleButton;
import java.io.BufferedReader;
import java.io.IOException;
import java.io.InputStreamReader;
import java.net.HttpURLConnection;
import java.net.URL;
public class MainActivity extends Activity{
    @Override
    protected void onCreate(Bundle savedInstanceState) {
        super.onCreate(savedInstanceState);
        setContentView(R.layout.activity_main);
    @Override
    public boolean onCreateOptionsMenu(Menu menu) {
        // Inflate the menu; this adds items to the action bar if it is present.
        getMenuInflater().inflate(R.menu.menu_main, menu);
        return true;
    @Override
    public boolean onOptionsItemSelected(MenuItem item) {
        // Handle action bar item clicks here. The action bar will
        // automatically handle clicks on the Home/Up button, so long
        // as you specify a parent activity in AndroidManifest.xml.
        int id = item.getItemId();
        //noinspection SimplifiableIfStatement
        if (id == R.id.action_settings) {
            return true;
        return super.onOptionsItemSelected(item);
       /*  This is a background process for connecting      */
      /*   to the arduino server and sending               */
     /*    the GET request withe the added data           */
    private class Background_get extends AsyncTask<String, Void, String> {
        @Override
        protected String doInBackground(String... params) {
            try {
                 /* Change the IP to the IP you set in the arduino sketch */
                URL url = new URL("http://192.168.1.177/?" + params[0]);
                HttpURLConnection connection = (HttpURLConnection) url.openConnection();
                BufferedReader in = new BufferedReader(new InputStreamReader(connection.getInputStream()));
                StringBuilder result = new StringBuilder();
                String inputLine;
                while ((inputLine = in.readLine()) != null)
                    result.append(inputLine).append("\n");
                in.close();
                connection.disconnect();
                return result.toString();
            } catch (IOException e) {
                e.printStackTrace();
            return null;
In this code you only need to change the IP to the IP of your arduino.
For checking the buttons you'll need to do 2 things:
  • Define the button
  • Add an onclick/onchange listener for every button.
Define buttons:
/* For a switch */
Switch led1 = (Switch) findViewById(R.id.Led1);
/* For a toggle button */
ToggleButton led2 = (ToggleButton) findViewById(R.id.Led2);
/* For a normal button */
Button led3 = (Button) findViewById(R.id.Led3);
Add onclick/onchange:
Place the onclick/onchange listeners in the onCreate function.
/* For a switch you'll need an "OnCheckedChangeListener" like this */
led1.setOnCheckedChangeListener(new CompoundButton.OnCheckedChangeListener() {
    public void onCheckedChanged(CompoundButton buttonView, boolean isChecked) {
        if (isChecked) {
            /* Switch is led 1 */
            new Background_get().execute("led1=1");
        } else {
            new Background_get().execute("led1=0");
/* For a toggle button you also need a "OnCheckedChangeListener" */
led2.setOnCheckedChangeListener(new CompoundButton.OnCheckedChangeListener() {
        if(isChecked) {
            /* Toggle button is led 2 */
            new Background_get().execute("led2=1");
        } else {
            new Background_get().execute("led2=0");
/* For a button you'll need a "OnTouchListener" */
led3.setOnTouchListener(new View.OnTouchListener() {
    @Override
    public boolean onTouch(View v, MotionEvent event) {
        if (event.getAction() == MotionEvent.ACTION_DOWN) {
            /* button is led 3 */
            new Background_get().execute("led3=1");
        } else if (event.getAction() == MotionEvent.ACTION_UP) {
            new Background_get().execute("led3=0");
        return true;
That's all the coding that needed to be done! Now we need to add permissions to your app.
Step 7: Adding Permissions to Your App
Picture of Adding Permissions to Your App
For your app to work you'll need to give it permissions. We only need 1 permission: Internet access. To give this permission you need to open the manifest file and add:
<uses-permission android:name="android.permission.INTERNET" />
Just before
Step 8: Resume
Picture of Resume
In this instructables I showed you how to control arduino IO pins over the network from an android phone.
I also included the full app directory for those who would like to use it.
I hope you liked it please leave comments and feel free to ask questions (There are no stupid questions ;) )
Laurens
JuanH86 (author)2018-01-05
Thanks.
Great work :D
DanielaP46 (author)2017-12-09
Hi!!! Can you help me please? I did all this and it was great! But now I need to read with the app and write it so I can create a notification
PatrykB4 (author)2017-11-07
Great work. I've download the whole package to see how it works but unfortunately I got around 19 errors while compiling :O Is it the obsolete code?
priyank123 (author)2017-01-05
i am getting error in app
action setting cannot resolve
what to do
IhsO (author)2017-01-05
I'm using pin 5 and i wanna switch on just one le, but it stil don't work for me? any helps please!
IhsO (author)2016-12-30
is it usefull for arduino uno with changing number of pins ?
Laurens-Wuyts (author)IhsO2016-12-31
Yes, this should work on an arduino uno.
If you, like you said, change the pins for the LED's.
Laurens
yhdesai (author)2016-09-20
I want to make the same thing but want to use bluetooth(HC-05) instead of ethernet/wifi shield. Could you please provide the codes regarding the same?
energyworks (author)2016-08-22
Hey man
Thanks for your amazing instructable "Control Arduino using android app"
I have learnt a lot reading your code and have tried implementing it for my project.
Everything works great. I have added a Write to EPROM to save the states of LED.
I want to send a String to my Phone after i switch on the LED. So that when i receive the string, my switch gets toggled.
I am doing it because when i close the app, it makes the switch to off state, i want the App to read the state of the LED from the arduino.
Thanks
KmosiaM (author)2016-07-21
Could you please help me with this error. I don't know what I am missing.
@Override
public boolean onCreateOptionsMenu(Menu menu) { // Inflate the menu; this adds items to the action bar if it is present.getMenuInflater().inflate(R.menu.menu_main, menu); return true;}
- I am having a problem with regards to the R.menu. it says it can't resolve symbol menu
- I am also having an error with the R.id.action_settings.
I thinnk maybe it's because they have not been defied as yet or am i wrong?/
please do help me ASAP
Laurens-Wuyts (author)KmosiaM2016-07-22
This is because of an update of android studio. You can just remove the functions onCreateOptionsMenu and onOptionsItemSelected
This should fix the error messages.
Laurens
Juanm215 (author)2016-07-07
Just an observation... in the line where you give the permission on the manifest, there was a ttping mystake:
<uses-permision android ......
it should be: <uses-permission android...
(the word "permission" is tiped with one "s" in this tutorial, instead of two )
I fixed that and it worked for me.
Laurens-Wuyts (author)Juanm2152016-07-07
Yes, my bad. I've changed it.
Thanks for letting me know.
Laurens
AhmadxonK (author)2016-06-01
Laurens-Wuyts thanks for tutorial dude. One question how to set status leds ? I mean in this app when you click button to on led , led will be on . But after that if you log out from app and run again, led will be off . How can i this
When I run android app I get these errors
AhmadxonK (author)AhmadxonK2016-06-01
I solved thanks dude
Laurens-Wuyts (author)2016-06-01
You can try and change targetSdkVersion to 22 in graddle.
Laurens
IbrahimE31 (author)2016-05-16
Hello again
I apologise for spamming but I am having a compilation error, "cannot find symbol variable menu" and for "action_settings" as well. I am not experienced in Android Studio, maybe it is something very stupid though
arturkuramshin (author)2016-03-12
Hello, is there a way the arduino could send a notification to the phone through this same method? If yes, could you maybe point me in the right direction? Thank you!
MahenM1 made it! (author)2016-02-29
hai, i try use only swicth only. but i cant trigger it. also the coding and the ino file no problem. same as you teach her. I need help.
Laurens-Wuyts (author)MahenM12016-02-29
Have you done step 7? (adding permission)
Is the IP address correct?
Can you see some error in logcat (in android studio)?
Laurens
guitarisnice (author)2015-12-09
Very nice project Laurens, you must have used some time on that project.
Do you think it will be possible to use RGB adressable leds instead of the ordinary leds you use? Have 200 rgb leds on a wood board that is controlled by a kepad and lcd today.It would be super nice if I was able using My phone instead.
It should be possible. The only limitation for this is your controller.
Laurens
bingdo72 (author)2015-09-22
This is good.
I have been searching some application references in which WIZnet solution is applied, and found your project using Ethernet Shield.
In the Ethernet Shield WIZnet's W5100 chip is embedded.
If you are O.K. I'd like to post this article in WIZnet Museum (http://wiznetmuseum.com) for others.
Laurens-Wuyts (author)bingdo722015-09-22
Yeah, you can do it. That would be cool!
Laurens
pucksurfer (author)2015-08-18
Cool! And... I had to ask... Is that a oneplus one?
Laurens-Wuyts (author)pucksurfer2015-08-18
Thanks.
It's indeed a oneplus one. :D
About This Instructable
34,384views
80favorites
License:
Bio: twitter: @Laurens_Wuyts
More by Laurens-Wuyts:How to Use the Beelink SEA I Media PlayerMinimalistic Led ClockControl Raspberry pi GPIO using an app
Add instructable to:
