Control LED Using IR Remote : Simple
Published
Introduction: Control LED Using IR Remote : Simple
About: So, I got a bunch of LEDs when I was 8 or 9 something.
Hello everyone, In this instructables we will control LED using IR remote.
Step 1: Gather the Parts
  1. A breadboard
  2. A LED
  3. A 220ohm resistor
  4. An Arduino UNO
  5. A TSOP382 IR receiver
  6. Some jumper or hookup wires
Step 2: Wiring
Hookup all the components according to the circuit diagram shown above.
Step 3: Receive the IR Signals From the Remote
Download Ken Shirriffs IR library from github then add the library to "Arduino installation location\libraries\"
Upload the following code to your arduino:
#include <IRremote.h
int IR_Recv = 2; //IR Receiver Pin 2
IRrecv irrecv(IR_Recv);
decode_results results;
void setup(){
pinMode(13, OUTPUT);
Serial.begin(9600); //starts serial communication
irrecv.enableIRIn(); // Starts the receiver
void loop(){
if (irrecv.decode(&results))
long int decCode = results.value;
Serial.println(decCode);
irrecv.resume();
Then open the serial monitor on your arduino IDE and receive IR decimal signals by pressing buttons on your remote for this project we'll need two IR decimal signals.
For me the IR decimal values are "3733801123" and "403429887" for Select and Power button respectively.
Step 4: The Final Code
Upload the following code to your arduino after replacing 3733801123 and 403429887 with your IR remote decimal code:
#include <IRremote.h>
void setup(){
void loop(){
if (results.value == 3733801123) //Select button
digitalWrite(13, HIGH);
Serial.println("LED turned ON");
if (results.value == 403429887) //Power button
digitalWrite(13, LOW);
Serial.println("LED turned OFF");
irrecv.resume();
Step 5: Done
Now just press the button of the remote whose code you assigned to your arduino to see your LED turning on and off.
Thanks for viewing.
Please write your questions or suggestions below.
Step 6:
    • Woodworking Contest
      Woodworking Contest
    • Planter Challenge
      Planter Challenge
    • Oil Contest
      Oil Contest
