Control LED Brightness With Remote and Arduino
7,198
14
Posted
Introduction: Control LED Brightness With Remote and Arduino
We will make a Remote Control LED brightness controller, it is very simple. Comment below your question if you have any, I will love to answer them all. My blog for Latest Tech News and Some Projects Electronics Time.
Step 1: Things You Need
  • Arduino
  • IR sensor
  • LED
  • Any Remote Control
  • Battery
  • Battery clip
  • Arduino Power Cord
  • Bread board
  • Some connecting Wires
Step 2: Circuit Daigram
Simply Hooking up IR receive pin to pin 11 and other two pins of IR Sensor to 5V Supply and Ground of arduino. Connect LED to pin 9 and Ground.
Step 3: Code
Simply run the code in your Arduino IDE and see the beautiful project i action. But, first check your remote control signal by using the IR library on Github. FYI the IR library runs on Arduino IDE 1.0.5 so, if you have arduino IDE version 1.0.6 then downgrade it to 1.0.5 after saving your projects to other place in your PC. Link For Previous versions of IDE.
Step 4: Video Tutorial.
Subscribe to my blog Electronics Time for latest projects and TECH news. Hope you Enjoy the project.
    • Spotless Contest
      Spotless Contest
    • Space Challenge
      Space Challenge
    • Science of Cooking
      Science of Cooking
    2 Comments
    Looking For This T_T
    Tnx ^_^
    Here is the code for Latest 1.6.4 IDE
    #include <IRremote.h> // use the library for IR
    int RECV_PIN2 = 11; // pin 1 of IR receiver to Arduino digital pin 11
    const int ledPin = 9;
    int Led = 4;
    int fadeValue;
    int lastCounter = 1;
    int counter;
    IRrecv irrecv2(RECV_PIN2); // create instance of 'irrecv'
    decode_results results2;
    void setup()
    Serial.begin(9600);
    pinMode(ledPin, OUTPUT);
    irrecv2.enableIRIn();
    void loop()
    counter = lastCounter;
    if (irrecv2.decode(&results2))
    if (results2.value == 1234924810)
    counter ++;
    if (results2.value == 4127085536)
    counter --;
    irrecv2.resume();
    if (counter == 5)
    digitalWrite( Led , HIGH);
    delay(500);
    digitalWrite( Led , LOW);
    delay(100);
    if (counter > 5){ //maximum for counter = 5
    counter = 1;
    if (counter < 2){ //minimum for counter = 1
    counter = 1;
    switch (counter){ //depending on the counter the fadevalue is sent to the led
    case 1:
    fadeValue = 00;
    break;
    case 2:
    fadeValue = 50;
    break;
    case 3:
    fadeValue = 120;
    break;
    case 4:
    fadeValue = 185;
    break;
    case 5:
    fadeValue = 255;
    break;
    analogWrite(ledPin , fadeValue); //set led with PWM value
    lastCounter=counter;
    Thankx for the concept
