Introduction: Control LED Using Local Wifi
Picture of Control LED Using Local Wifi
We may require to transmit data from the board to other devices at some point or another.
Linkit one provides us with many options like GSM, GPRS, Bluetooth, micro SD, Audio and WiFiLinkit one has built in WiFi module, which can be used to transmit and receive data through WLAN.
Thus in ths instructable I'm gonna show you how we can control the onboard LED through local Wi-Fi.
Step 1: Connections
Picture of Connections
Since Linkit one already has all the necessary hardware inbuilt, we just need to connect the WiFi/Bluetooth antenna to the board
Note: The antenna connector socket is very delicate, connect using soft hands
Step 2: Wi-Fi Connection
Picture of Wi-Fi Connection
You will need a WiFi router (regardless of internet connection)
Once you have set up the router, note the Network SSID, the Network Password and encryption type (WPA/WEP/OPEN)
Note: Mobile hotspot will also do
Step 3: Code
I have attached my code with the instructable, you'll need to edit the Network SSID and Password with you SSID and password on line 5&6.
In the code I'm controlling the digital state of the LED through inputs provided by a host, you may edit the code to print analog inputs, inputs from sensors, or anything you can imagine to do with the board.
Step 4: Compile, Upload, Run
Picture of Compile, Upload, Run
When you upload the code to the board, open your serial monitor
Copy the IP address that is displayed(You can now close the serial monitor and arduino software if you wish)
Paste the IP address in your browser and you may see the output like in the picture
seamster (author)2015-11-24
Pretty cool. What kinds of applications would you use this for?
tejalmamaniya (author)seamster2015-12-06
Well you can create a textbox and send back string to the board. Then matching different cases perform different actions
1 example I can think of could be a WIFI controlled bot
gagananand066 (author)2015-11-27
what is this ? i didnt understand
We are basically establishing a 2-way communication via WLAN. In my instructable I've controlled an led, you can send values and control servos, passcodes, etc
About This Instructable
896views
11favorites
License:
More by tejalmamaniya:Digital object counter using PIR and Linkit OneMaking a GeoFence using Linkit OneConnect Linkit One to ubidots for IoT
Add instructable to:
