Control Servos over the Internet via Arduino with Teleduino
 by nathanknz
Servos have many uses and can be a lot of fun to play around with. Something that can be heaps of fun is taking control of up to six servos over the internet! Just imagine the possibilities.
This process is made really simple using the Teleduino sketch for your ethernet enabled Arduino. Haven't heard of Teleduino? That's cool, you may want to take a look at Arduino Control via a Web Service with Teleduino to get yourself started. It's designed to be quick and easy for rapid development.
This tutorial will guide you through the process of attaching a servo to your Arduino, and provide some example Teleduino API call to:
  • Define a servo instance
  • Set the position of a servo
If you get stuck on any of the steps, or if you feel that there is a step that could be explained better, please leave a comment so that we can improve things.
Let's go!
Step 1: Parts Needed and Circuit Diagram
Parts Needed
You need the following parts to complete this tutorial:
  • Ethernet enabled Arduino with the Teleduino sketch loaded
  • Breadboard (optional, but makes prototyping much easier)
  • Dedicated 5V power supply for the servo(s) (optional, but recommended because servos can draw high current causing your Arduino to reset)
  • Servo
  • Some hookup wire
Circuit Diagram
The circuit is pretty simple, but sometimes a picture can paint a thousand words! Take a look at the attached circuit diagram to see how to connect the servo to the Arduino board and external power source.
member01 says: May 9, 2013. 9:39 PM
I got the LED Teleduino Instructable working fine but got stuck when it came to the Servo controls over Teleduino. It would drop out and lose connection periodically unlike the LED that worked every time. I think this is down to me not using a dedicated power supply for the servo and the Ardunio wigging out. I am getting a switchable DC power supply tomorrow and will test and update.
nathanknz (author) in reply to member01May 11, 2013. 1:12 AM
Hi member01,
Thanks for your comment. I believe your findings would be correct - you will most likely require a separate DC power supply for the servos.
Have fun with your projects!
mapache101 says: Nov 4, 2012. 8:28 PM
It worked like a charm! thank you.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
