Control Speed Motor PID
Introduction: Control Speed Motor PID
This is briefly instruction to control motor speed using PID algorithm. Also in this project, motor speed will be print out at computer screen
Step 1:
Connect motor to Arduino through H-bridge
Program Arduino as:
void loop() {
if (stringComplete) {
// clear the string when COM receiving is completed
mySt = ""; //note: in code below, mySt will not become blank, mySt is blank until '\n' is received
stringComplete = false;
//receive command from Visual Studio
if (mySt.substring(0,8) == "vs_start"){
digitalWrite(pin_fwd,1); //run motor run forward
motor_start = true;
if (mySt.substring(0,7) == "vs_stop"){
digitalWrite(pin_bwd,0); //stop motor
motor_start = false;
if (mySt.substring(0,12) == "vs_set_speed"){
set_speed = mySt.substring(12,mySt.length()).toFloat(); //get string after set_speed
if (mySt.substring(0,5) == "vs_kp"){
kp = mySt.substring(5,mySt.length()).toFloat(); //get string after vs_kp
if (mySt.substring(0,5) == "vs_ki"){
ki = mySt.substring(5,mySt.length()).toFloat(); //get string after vs_ki
if (mySt.substring(0,5) == "vs_kd"){
kd = mySt.substring(5,mySt.length()).toFloat(); //get string after vs_kd
void detect_a() {
encoder+=1; //increasing encoder at new pulse
m_direction = digitalRead(pin_b); //read direction of motor
ISR(TIMER1_OVF_vect) // interrupt service routine - tick every 0.1sec
TCNT1 = timer1_counter; // set timer
pv_speed = 60.0*(encoder/200.0)/0.1; //calculate motor speed, unit is rpm
//print out speed
if (Serial.available() <= 0) {
Serial.println(pv_speed); //Print speed (rpm) value to Visual Studio
//PID program
if (motor_start){
e_speed = set_speed - pv_speed;
pwm_pulse = e_speed*kp + e_speed_sum*ki + (e_speed - e_speed_pre)*kd;
e_speed_pre = e_speed; //save last (previous) error
e_speed_sum += e_speed; //sum of error
if (e_speed_sum >4000) e_speed_sum = 4000;
if (e_speed_sum <-4000) e_speed_sum = -4000;
e_speed = 0;
e_speed_pre = 0;
e_speed_sum = 0;
pwm_pulse = 0;
//update new speed
if (pwm_pulse <255 & pwm_pulse >0){
analogWrite(pin_pwm,pwm_pulse); //set motor speed
if (pwm_pulse>255){
Step 2: Work at Visual Studio C++
Coding in Visual Studio C++ is quite long, see code at this link
Step 3: RUN It
Run it with speed as you wish
See more instruction at our blog:
    • Pocket-Sized Contest
    • Pro Tips Challenge
      Pro Tips Challenge
    • Paper Contest 2018
      Paper Contest 2018
    Is there an equivalent motor that can be used for this system, it is very difficult to find the DSE38BE27-001 AX060121 DC motor with encode.
    you can use any dc motor which has encoder, then find factor kP kI kD for it.
    Thank you so much for the answer, there is one more concern I have. I will be using a motor that has an encoder with 211.2 counts per revolution, can this code in C++ be able to handle the amount of data that will be flowing through it at 2000 RPM (ie. there will be over 1 million points of data a minnute or 10,000 points a second. )?
    I'm not sure. Let's try
    Thank you for the help! Also I believe I figured out my issue, I am using a Sparkfun Promicro 5V arduino. And I think the amount of data flowing through it is overloading it, because i keep getting a sub-string error that says the length of the string is overloaded, and when using an arduino uno I don't get this issue.
    You can use any type DC motor which has encoder! then find PID factor for it.
    Another question, is there a step somewhere that will allow me to change the PORT selection without having to use PORT4 every time?
    You need to add one more function to change port name for COM port
    I think it should has exception error to prevent program error if port name is wrong. Let's try yourself first.
    Would you please give the precise specs for the motor and the link for it
    It's here bro
