Introduction: Control WeMo Switch With Arduino+Ethernet Shield
There are many apps that let you control your Belkin WeMo devices, but there is no a hardware switch panel like the Hue Tap for Philips hue.
So I build one with an Arduino!
Step 1: Materials
For this project you need:
- An Arduino board. I use the Arduino UNO but you can use any board that is compatible with Ethernet shield.
- Arduino Ethernet shield. You need the ethernet shield to connect the arduino to the local network.
- On/Off switch
- 10k Ohm Resistor
- Arduino Proto Shield + mini breadboard
- wires
- also use a card box as a case for the project
Step 2: Schematic
Step 3: Code
Load the code to the arduino.
On the code you need to set the IP address an the port of your Wemo device (variables wemoIP and wemoPort):
char wemoIP[ ] = "192.168.2.126"; //set the IP of your WeMo device
int wemoPort = 49153; //set the port of your device
