Control Your Bedroom Lights With a Simple DIY Push Switch
Introduction: Control Your Bedroom Lights With a Simple DIY Push Switch
Improve Your Room Youth Design Challenge
Grand Prize in the
OK, we'll just say you've just finished watching a scary movie per say, the grudge or something. When I watch a scary movie i walk into my room, turn the light on walk to my bed turn my night lamp on than go to the door to turn my bedroom light off. Yes, its true, after watching a scary movie we don't really want to be in the dark unless if we are under our actual covers.
So in this instructable i'm going to show you how to prevent that by "improving" your room.
Please vote for me in this contest and thanks!
Now moving on....
Step 1: Your Materials
Sorry but only a few of the materials have pictures.
The materials needed for this are,
a motor
a soldering pencil
2 push switches
duct tape
batteries (9V)
battery connectors
wire cutters
Step 2: Connect the Batteries and Push Switches Together
so first connect 2 wires to your switches, one per lead. Than connect one of your push switches leads to a negative (black ) terminal of one battery connector, and the other push switch connects one of its  wires to the positive lead of the other battery connector. So right now you still have two different parts.
The last two pictures show that the wires on the push switches that are not connected to the battery holder have to be connected together, with another wire that is as long as the wall you want to run it across. Its a 3-way connection.
Step 3: Connect the Motor
Ok, so take the two wires you just spliced together and connect that to a lead on your motor.
Next connect a length of wire to the other lead on your motor.
Step 4: Connect the Rest of Your Circuit
Take that wire and cut it the same length as your other long wire.
Connect that to the last two unused leads, the ones on your battery connectors. (I soldered them)
Don't forget to use electrical tape!
Step 5: Creating Your Control Box
Using plexiglass I got from hobby lobby I made a small box about 1'' by 2'' using hot glue on the seams.
I made 2 small holes for my push switches to show through. After that I made a hole for the wires to come through.
Do Not Put The Batteries In The Box, for when they run out of battery you will be pretty upset.
Step 6: Find an Adequate Place for Your Control Center
I found a nice spot under my nightlight next to my bed as mentioned in the story at the beginning.
I used duct tape to secure it because it will stay put but not a problem if I end up having to move it
Step 7: The Motor Stand
After the "hard" work i made a stand to hold the motor using cardboard and double sided tape. But you can use whatever you want and make it more colorful.
Now your ready to connect the motor and since it s on cardboard or plastic or something you can hot glue it.
Step 8: Finishing Up
now all you have to do is put on a lever.
After much experimenting i used an orange knex connector piece because the length was perfect, it fit on nicely, without glue, and if it snapped off, it didn't break and could go right back on.
Thanks for viewing and please vote for me!
    • Pocket-Sized Contest
    • Pro Tips Challenge
      Pro Tips Challenge
    • Paper Contest 2018
      Paper Contest 2018
    Ummmm, we'll let me think it over.......
    can i have your 3d printer
    Nice job! this looks to be a very simple H- bridge that you made :D
    Good job! Although I can't honestly say I am not bitter about losing the 3-D printer you deserve it. Have fun printing stuff! You deserve it.
    Thanks!! And thanks to anyone who voted for me
    Looks sweet man!
    Congrats on the 3D printer!
    I hope to see some awesome projects!
    If you don't have knex, I'm sure sugru will work too
